What I learned about scraping in a compound slide tonight.
Results 1 to 1 of 1
    Mar 2010
    pacific northwest
    1,054
    6
    221
    Default toolpost bolt force can warp compound
    What I learned tonight--Scraping in a small lathe compound is a lot different than a milling machine knee. They move more.
    Captain Obvious reporting for duty--!
    It won't matter how well the compound is fit unless the toolpost is fit to the compound. Scrape in the top of the compound in the tee slot area, , and the base of the toolpost, and secure the toolpost to the compound. Then put it on the surface plate.
    Since I had already scraped the compound, there was a ready made reference for how much change putting the toolpost on would make- I looked at it and thought, ya know, that toolpost could put a lot of movement into that little thing- put on the toolpost, and reblued on the plate and it was back to touching opposite corners.
    Then I scraped the toolpost bottom, and the top of the tee slot area, put the toolpost back on, and the compound was back to almost flat.
    It's getting there...
  2. Likes Yan Wo, Screwmachine, Mud, CBlair, jjinpdx liked this post
