What paint do you recommend for a lathe reconditioning?
Page 1 of 3 123 LastLast
Results 1 to 20 of 48
    Mar 2008
    alberta canada
    Default What paint do you recommend for a lathe reconditioning?
    I have picked up a Lion C11MT also known as Mashstroy lathe
    that I'm fixing up. I would like to repaint it before installing it.
    What paint do you recommend that's tough to use on machinery?
    Is there any specific prep work that's recommended other than sanding?
    May 2014
    Greece
    19
    8
    Hello Freddy
    Recently i repaint mine mashstroy c11 mtm. I rubbed with fine sandpaper, cleane it well and use ABF colour green vegetable.I am happy with the result.
    Feb 2008
    Paradise , California
    1,804
    263
    493
    Look at tractor paint its cheap and durable .
    Jun 2006
    Munich / Germany
    2,140
    342
    1069
    I only use 2 component PU paint. The brand I use is MIPA, maybe only available in Germany/Europe. Suggested use is tractor / truck / machinery.
    Nick
    Sep 2002
    Lawrenceville GA USA
    6,175
    697
    1315
    In the US Imron is likely the paint of choice, it has been reformulated over the years so it is different than the old Imron paint but it is still a tough and durable industrial product. There is also a line of high fill or thin primers that work with the paint.
    Charles
    Mar 2007
    England UK
    1,792
    740
    736
    I use a plain grey acrylic floor paint. It's very hard-wearing, but gives a somewhat matt finish.
    Feb 2013
    California, USA
    78
    315
    40
    I find that the key to a durable paint job is in the prepping and also making sure you let the paint dry for at least a weak before using the machine. I use rustolium "machine grey" on my machines and if you have done your part in the prep and let the paint dry fully then it is very tough. I'm sure some of the paints mentioned above are better but again I think the results you get are mostly based on your prep and proper drying time.
  8. Likes nsaqam liked this post
  9. #8
    Dec 2012
    Northeastern California
    119
    251
    80
    Any good hard-working enamel will work. If you want more durable, go with an epoxy (but don't forget your PPE's!!!) - Imron is good, but you need supplied air and gloves and stuff, and the old stuff needed a moon suit to shoot safely. Seriously toxic stuff.
    The ultimate is Powder Coating, but you have to be careful with your mating surfaces, as it changes dimensions to the stuff being powder coated.
  10. #9
    Sep 2002
    6,175
    697
    1315
    Quote Originally Posted by Lassen Forge View Post
    I am sure it was, I painted an engine block with Imron in 1989 in a tee shirt and facemask....maybe that explains a few things now.
    Charles
  11. Likes Spinit, antique lathe, thermite liked this post
  12. #10
    May 2012
    Indiana
    954
    178
    349
    Imron is dangerous and should be applied by a professional only.
  13. #11
    May 2007
    2,598
    3051
    479
    I have also exposed myself to many things over the years. It is much better today than years ago and at least we have MSDS books and can check on things. Carbide dust from grinding is some nasty stuff. Various chemicals are also. I have heard from experienced painters that paints can be unsafe if not used properly.
  14. #12
    Jul 2007
    UNITED KINGDOM
    4,608
    2389
    2175
    Sorry to contradict the hysteria, but isocyanate cured polyurethanes such as Imron merely require good practices and care. Use a disposable hooded overall and gloves. Supplied air is good, if drawn from a contamination free source, but companies such as Dräger produce breathing mask filters that work perfectly well with isocyanates. Don't get the un-cured stuff or hardener on your skin. Follow those rules and you'll be as safe as a 'professional'. If you get sensitized to it, it doesn't matter whether you're an amateur or a professional, you won't be able to use it again without danger.
    While on the subject of painting machines, If useing a 2 pack acrylic high-build primer, beware of getting too thick a layer in an attempt to remove all traces of casting marks. It's not particularly tough and can lead to an easily chipped finish after covering with the 2 pack PU paints.
  15. Likes Demon73, neilho liked this post
  16. #13
    Jun 2011
    California USa
    99
    15
    I have done two lathes and a BP mill. First lathe was done with Centari acrylic enamle with a urethane hardner, did a good job and easy to use and spray. When I did the mill my supplier couldn't sell Centari anymore in California so he recommended PPG Omni 2P urethane. Compared to the Centari it was crap to work with, nothing but runs and drips and no coverage, was almost as thin as water, will never use it again. On the second lathe I went with a 2P epoxy from Klasskote and it worked really nice, was full bodied and was easy to spray or brush. Was not quite as glossy as the urethanes but looks nice. With the epoxy, no primer is needed over bare metal, it's resistant to most all solvents and lubricants and can be ordered in quart or half gallon kits.
    Craig
  17. #14
    Mar 2008
    alberta canada
    thanks for all the suggestions. My first thought was to use International paint.
    That's the choice of paint where I work on all steel structures.It seems tough.
    I'm going to check and see whats available of the suggestions I got here.
  18. #15
    Sep 2002
    6,175
    697
    1315
    Freddy the best advice is to go to the local professional paint store, not the home center stuff but the automotive and industrial suppliers. It is best to get advice and supplies from them as you will not have the problem of incompatible layers or running out of something and not being able to get more when you need it.
    Let them know of some of the suggestions and see what comparable product they have.
    Charles
  19. Likes matt_isserstedt, Richard King liked this post
  20. #16
    Mar 2008
    alberta canada
    I went to an industrial paint store and got a Devoe industrial alkyd paint.
    It is fast drying and so far its easy to work with. The primer is quite filling and fast drying as well.
    I have painted the chip tray ,coolant tank and back splash guard. I'm happy with the results so far.
  21. Likes kpotter, Richard King liked this post
  22. #17
    Jun 2014
    Arizona
    34
    If it were me, I'd use a good epoxy paint. Its very impervious to chems etc.
  23. #18
    Sep 2002
    6,175
    697
    1315
    Quote Originally Posted by freddygotarf View Post
    Well keep us informed Freddy, oh and I am sorry but your user name really has me baffled...I cant see it without thinking Freddy Goat Fart....even thought I know that is not how it is spelled.
    Charles
  24. Likes thermite liked this post
  25. #19
    Jul 2008
    Sydney, Australia
    3,726
    2056
    1287
    Oh this is an easy answer. "Real Machines" only ever come in one colour; RAL 6011, Reseda Green
  26. Likes Ocean liked this post
  27. #20
    Mar 2005
    near Rockhampton, Queensland, Australia
    5,498
    439
    2046
    Quote Originally Posted by Pete F View Post
    What shade of pink is that Pete????
