What PPI under the headstock?
Results 1 to 9 of 9
    Mar 2007
    England UK
    1,792
    740
    736
    Default What PPI under the headstock?
    I'm scraping under the headstock of my practice-bed. I am wondering what is the typical scraped PPI that the headstock bears onto? Surely it doesn't need to be as high as on the ways?
    Jun 2004
    Melbourne Australia
    5,458
    If that was me. Thats a static surface, your only scraping for alignment, If you went past 12 P.P.I, your over working it. Any thing better than 8 is good. And its a dirrerent kind of scraping to slides. You want more contact, for a mechanically coupled / bolt on assembly, so bigger radiused tip leaving larger lands, for me increasing percentage of contact.
    Regards Phil
  3. Likes lowCountryCamo, Peter. liked this post
    Jul 2005
    Cottage Grove, MN 55016
    7,506
    4066
    4489
    I agree, but I say 5 to 10 PPI and stone a bit harder then when scraping ways. Around holes I recommend you counter sink the threads or slightly counter bore so when you tighten down the bolts the threads don't pull up and twist the head or unit. I make sure to get more POP percentage of points of contact and I also make sure the bottom isn't high in the middle 40% is .00005 to .002" low. Many builders relieve the middle a lot and only have bosses or a flange that they set on. I was just talking to Vette Bob yesterday on the phone and he fit his EE head to his newly ground bed as he purchased a test bar from a place Jim Thelie told him about. He said he read how to scrape it on the monarch thread. :-) Be sure to tighten the bolts down when there is still bluing under there to know you aren't getting a false reading when it isn't tight. If you think your getting a false read, with the head loose tap on the 4 corners with a plastic covered lead hammer or dead blow hammer to hear if you get a solid thud sound. also I see if I can slide in a .001" under the flanges. Rich
  5. Likes lowCountryCamo, Peter. liked this post
  6. #4
    Jun 2006
    Munich / Germany
    2,140
    342
    1069
    10 PPI is my vote too.
    Read that again!
    Especially if one side has a thread (means: no through holes where a bolt with nut goes through). You will be shocked how much a bolt that goes into a thread pulls out the thread and thus you only get ring-contact around the thread.
    So if there is a thread in one part, generously relieve it.
    Nick
  7. Likes Richard King liked this post
  8. #5
    Jun 2004
    Melbourne Australia
    5,458
    Quote Originally Posted by Nick Mueller View Post
    Back in the company where I did my time. They had a standard proceedure for any critical threaded holes, for any where a hardened rail, headstock, spindle housing, turret etc was to be installed.
    That was to drill 3x diameter of bolt. So 36mm deep for a M12 bolt. Tap to 2.5x, then pull the first 3 threads out with a nominal size drill 3 x 1.75mm depth at Dia 12 for M12 etc. Then put a generious chamfer on top of that. They used to grind sub-land drills to do it in one shot. That would be similar to the counterbore Rich mentioned.
    I see this a lot on lessor built machines, where you are replacing a linear guide. You run a stone over the seat, and theres mushroom shaped lands around the holes.
    Regards Phil.
  9. Likes Tyrone Shoelaces, RC99, Richard King liked this post
  10. #6
    Jun 2006
    Munich / Germany
    2,140
    342
    1069
    That sounds like a very good procedure to me!
    Nick
  11. #7
    Apr 2006
    Manchester, England
    7,975
    1116
    4961
    Standard procedure at the company I worked for last. Regards Tyrone.
  12. #8
    Mar 2007
    England UK
    1,792
    740
    736
    One of the first things I noticed on my practice-bed was a raised atoll-ring of metal around the four headstock mount threaded holes. I never thought to mention it. I had originally relieved it with the scraper, didn't realise you had to go as deep as 3 threads.
  13. #9
    Jun 2004
    Melbourne Australia
    5,458
    Quote Originally Posted by Peter. View Post
    Atoll , must be the best ever word to describe pulling up metal. Thanks for mentioning it.
    Regards Phil.
