What are You Scraping On?? - Page 25
Page 25 of 27 FirstFirst ... 152324252627 LastLast
Results 481 to 500 of 536
  1. #481
    Dec 2009
    Germany, Bavaria
    124
    94
    153
    n fact, I've threatened Corey more than a few times with kidnapping and enslavement. I figure if I chain him in the corner with the 10EE I can leave one of those self refilling water bowls and just toss some stale bread into the corner until he finishes it up for me.
    But then, every unnecessary surface would be perfectly scraped too!
    I have again a Schaublin 102 compound (and cross slide) on my bench.
    No heavy wear, but enough to bother the owner (It would bother me too), the slide binds up on the ends as usual, when the gib is set reasonable tight.
    Numbers are in 1/1000mm:
    I sure love that new surface plate
    Stefan
  2. #482
    Sep 2004
    RSA
    1,107
    394
    279
    Quote Originally Posted by StefanG View Post
    Stefan
    High quartz content ?
  3. #483
    Dec 2009
    Germany, Bavaria
    124
    94
    153
    Might be, judging by the color/flecking. But as far as I know, not everthing bright in the stone is quarz..
    (And someone told me that Quarz can be a problem, as far as piezoelectric effects goe. But thats a few levels above my paygrade.)
  4. #484
    Apr 2010
    Wisconsin
    5,709
    4067
    3392
    LOL! That's fine by me.
    Besides, you shouldn't make fun. If you were any closer, I'd come kidnap you as well, and chain the two of you together.
    Hmmm....
    I might be able to fool... err... I mean talk Corey into going to IMTS. If I could get you to do the same, I could save on my own travel time and accomplish two tasks at once.... LOL.
    When you two are done with the Monarch, I would just drop you off at Kinetic and let Cash chain you guys in the corner to work on all those 4 meter straight edges. LOL.
    I've been following your progress on that one. Superbly done, as usual.
  5. Likes capocoreyollo, Richard King liked this post
  6. #485
    Sep 2004
    RSA
    1,107
    394
    279
    Well, it'll last longer, that's for sure. Gage blocks won't like it as much but I have yet to wear one out. Few years ago I lapped a couple for a client and they really lasted well.
  7. #486
    Jul 2005
    Cottage Grove, MN 55016
    7,090
    3799
    4229
    Stefan
    Stefan see what I mean about straight oil grooves :-) ?
    Looks good, but I would zero the indicator in the low area and read plus, because thats where you will be scraping. Are you near the Austrian boarder by chance? I will be teaching there in November. Would be nice to something at Hobby Himmel again. :-)
  8. #487
    Jul 2014
    GERMANY
    45
    24
    28
    Keyword "oil grooves" ...
    There is a video (moderate quality), that shows the flow of the (black) fluid in a unusual pattern of oil grooves:
    SKC_Gitterschmiernut.mpg - YouTube
    The pattern looks like joints in a wall. I guess, it seems to be interesting for lubricating large areas.
    Source (click on the topic "groove foil"):
    Accessories – SKC Gleittechnik
    Catalogue of the accessories:
    http://www.skc-technik.de/content/wp...ccessories.pdf
    I don't know, if such patterns are useful, but perhaps in some cases it could be thinkable to make oil grooves like such ones, but without molding.
    Cheers,
    Karl
  9. Likes Richard King, StefanG liked this post
  10. #488
    Jul 2005
    7,090
    3799
    4229
    Karl, thanks for sharing that! That must be a similar product as Mogice.
    Next time the readers are in a shop and at looking at the ways of a machine and you see a raised long area on the exposed side of a way, your looking at what a straight oil cut into the mating surface. That is why I have been preaching for years to never cut in straight oil groves into ways. :-) Look at Stefan's last picture and see what I mean. Rich
  11. Likes CharlyDE liked this post
  12. #489
    Jul 2014
    GERMANY
    45
    24
    28
    Hi Richard,
    yes, that company (SKC Gleittechnik) produces similar products as Moglice.
    Thank you for your explanation. If I understand it right, then a straight groove parallel to the sliding direction will cause not wanted less wear in the mating surface.
    I guess, that it should be better to positon a pattern of oil grooves (like that from SKC) in a manner, that none of the grooves are parallel to the sliding direction.
    Cheers,
    Karl
  13. Likes Richard King liked this post
  14. #490
    Dec 2009
    Germany, Bavaria
    124
    94
    153
    The gib of the compound was worn beyond useability - We didnt want to wait for a replacement by Schaublin and the customer didnt want a shim behind it, so I machined a new one from cast iron.
    The taper still needs to be fitted by scraping, but it is very close after milling it - maybe 0,01mm off over a distance of 80mm.
    Ha! I might figure something out, at least to drop by for a day, I want to see the shop of Franz anyway
    Stefan
  15. #491
    Feb 2011
    1,536
    693
    570
    Don't think I ever posted these results. This is the surface plate I brought to the 2017 Texas class. It's an 8" x 16" and looks similar to a Brown and Sharpe but isn't marked as such. It has a "Machinery MFG. Co." tag but I think that's just an old inventory tag.
    I'm counting 20-25 PPI on average at this point. If it was a machine I'd stop, but because it's for inspection, I want to continue splitting them until I'm getting 35-40 PPI. I'm going to wait until one of our granite plates is certified A grade before I continue. We unfortunately don't have certs on our plates and have never had a problem with them, but we are planning on getting them certified and if needed serviced in the near future.
    No pics right now, but I'm also scraping in a 24" Dovetailed King-Way straight edge that I'll be using on the Cincinnati Universal Tool and Cutter grinder I'm rebuilding.
    Not sure what will be the next machine after that. I'd like to dig into the ways and crosslide on my 16" Hendey, but lack the time and space to devote to tearing it down. I want to get a 8' straight edge and a larger surface plate to check it with before I start on it. I know it can be done with shorter straight edges, but I'd like that lathe to be top notch accurate when it's done.
    At some point I'll also be rebuilding our old 10" South Bend, Kearney Treacker 2H, Cincinnati 2L, and the old round ram Bridgeport in my garage.
  16. Likes lucky7, 4GSR, Richard King, swatkins, dcsipo and 1 others liked this post
  17. #492
    May 2018
    AUSTRIA
    8
    20
    Hello together,
    one of our last Jobs was a complete rebuild of a Deckel FP3NC.
    The greatest problem was a long and deep scratch on the Front way of the Z-Axis.
    We fixed it with a GGG50 (original material) inlay.
    After scraping there is nothing more to see :-)
    Scraping Parameters:
    Powerscraper Biax BL10
    Scraper Blade Biax 5/8" 15-150 Radius 50mm
    Stroke between 2/16 and 3/16
    around 30ppi with 50%
    Depth .0003"
    regards, Franz from the Lüftinger Brothers :-)
    Attached Thumbnails Attached Thumbnails staender-fertig4.jpg   staender-fertig3.jpg   staender-vorher.jpg   staender-vorher2.jpg   staender-fertig.jpg
  18. #493
    Jul 2005
    7,090
    3799
    4229
    I met the Luftinger brothers last year in Germany when the attended one of my classes. They knew how to handscrape to 40PPI and I helped them how to scrape 40 PPI with their BIAX scrapers. Their history is a lot like mine, their Father taught them how to rebuild machinery and scrape and when he passed, they took over his company. I'll let them tell more....They introduced me to store bought ground lapping stones and I have to admit the work 100% better then the Norton stones I give out during the classes. The plan BIAX and I have is when I retire they will take over the European Classes Biax Hosts.
    Attached Thumbnails Attached Thumbnails 20171129_092506.jpg   20171127_164516.jpg   20171128_114027.jpg   img-20171201-wa0001.jpg
  19. #494
    Oct 2014
    Maryland
    2,593
    1555
    1694
    Quote Originally Posted by Richard King View Post
    Stefan see what I mean about straight oil grooves:-)?
    Looks good, but I would zero the indicator in the low area and read plus because that's where you will be scraping.
    Makes sense , but you those Germans, they like things complicated . In Stefan's defense, sometimes things just end up that way, you zero where you think it is low, and then there is the place you did not think of .
    dee
    ;-D
  20. #495
    Dec 2016
    Washington
    310
    85
    84
    Not exciting enough for picts - rough scraping the bottom of my milling vise with a newly arrived, Biax 7ELM/carbide blade. Nice tool.
  21. #496
    GERMANY
    2,117
    1123
    679
    Hallo Franz,
    Quote Originally Posted by MASCHRATUR View Post
    One of our last jobs was a complete rebuild of a Deckel FP3NC. The greatest problem was a long and deep scratch on the front way of the Z-Axis. We fixed it with a GGG50 (original material) inlay. After scraping there is nothing more to see :-)
    That's nice work!
    I had a question for you. On the rebuilt Deckel FP2/3/4 machines that I have seen (for example, those from Franz Singer) the Z-ways are ground, and then the saddle is scraped to fit. Why did you decide to scrape the Z-ways rather than having them ground?
    Cheers,
    Bruce
  22. #497
    Jul 2005
    7,090
    3799
    4229
    I was looking on You Tube and saw this. Pretty interesting, Hand scraping different materials.
    Modified scraper.. - YouTube
  23. #498
    Feb 2011
    1,536
    693
    570
    Here's the 24" dovetail'd straight edge I'm working on at the moment. I rough scraped mostly through the plaining before I started checking it. I'm roughing all 3 sides in together so I can see how the overall piece is shaped. I'm scraping the back of the heal in as well as I'll need it to check the slide-way on the tool and cutter grinder I'm rebuilding, which has an upside-down box-way of sorts. I found that the straight edge has a bow going through it making the dovetail side high in the middle and the opposite side high on the ends. Then the heal has a little twist to it so 3 corners made contact and the 4th didn't. Nothing that can't be corrected, just takes some time. The dovetail side was the first to flaten out, now I just need to finish getting to the low spots on the other 2 sides.
    I'm using my old blue biax running at half speed (Variac) with a 3/8" stroke, and a #25 blade.
  24. Likes Richard King, ballen liked this post
  25. #499
    Jul 2005
    7,090
    3799
    4229
    Those young castings will move especially when your scraping them for the first time. I always say scrape one side till you get 5 to 10 PPI and rotate to another side and when they are all done go back to side one and finish it to 20 - 30 PPI and rotate again and do it all again to reach 38 - 42 PPI.
    I would most definitely wring (Vibration stress relief) it like a bell on a rope several times during the process,
    Looks good. Oh I never scraped the back of heel until Stefan G was scraping a grinder when we were teaching a class last year in Stuttgart and the back side fit perfect, so we scraped the back.
    Rich
  26. Likes M.B. Naegle liked this post
  27. #500
    May 2018
    AUSTRIA
    8
    20
    Quote Originally Posted by ballen View Post
    Hallo Franz,
    That's nice work!
    Cheers,
    Bruce
    Hello Bruce,
    sorry i have overlooked your question.
    it is quite simple, just grind is cheaper than scraping both Sides of the Way.
    In our experience (25 years machine rebuilding), non-hardened Ways last longer if both sides are scraped.
    many rebuilders we have seen, grind the ways an then just flake the carriage.
    No real scraping und no match fit :-(
  28. Likes Paolo_MD, ballen liked this post
