What's better Linear Ways or Scraped Ways ?
Page 1 of 2 12 LastLast
Results 1 to 20 of 23
    Jul 2005
    Cottage Grove, MN 55016
    7,683
    4126
    4575
    Default What's better Linear Ways or Scraped Ways ?
    I figure the forum needs a new subject. Here is a magazine article I contributed too back in 2015.
    Scrape to the point | Cutting Tool Engineering
    Mar 2005
    near Rockhampton, Queensland, Australia
    5,541
    441
    2070
    They did not mention hydrostatic ways.
    Jul 2006
    Hillsboro, New Hampshire
    7,829
    1827
    5505
    The ultimate must be scraped linear ways, with flaking on all the rolling elements and rails.
  4. Likes lucky7 liked this post
    Dec 2000
    Bremerton WA USA
    10,698
    41
    4278
    Good survey article apparently intended for design staff and supervision unfamiliar with the comparative merits of linear bearing systems.
    While the article couldn't cover everything (hydrostatic bearings, alternative lining materials, machine tool survey, buy Vs build, prep for rebuild, etc), it omitted scraping assembly joints for correcting alignment and scraping bearing surfaces for geometry and fit. A good tech writer could have synopsized these sub-topics in a single paragraph - enough to plant a nugget in the mind of a technical decision maker.
    Most folks with only a vague knowledge of scraping are unaware its niche applications, including accurizing the mounting surfaces intended for linear bearing assemblies. It would be beneficial if the decision makers were at least aware of these refinements and of source material, bibliographies, etc for further study should they be so inclined.
  6. Likes cyanidekid liked this post
  7. #5
    Jan 2007
    Flushing/Flint, Michigan
    8,089
    414
    6677
    People hand scrape linear bearing mount surfaces or even bearing locknuts...
  8. #6
    Apr 2018
    UNITED KINGDOM
    2,843
    1322
    Quote Originally Posted by RC99 View Post
    Landis cam grinders have the kind that are pressurized. Is that hydrostatic or hydrodynamic ?
    Whichever, they are the coolest. Makes everything else look like junk.
  9. #7
    Mar 2013
    Surbiton, surrey, UK
    1,634
    2015
    1051
    Obviously, the correct answer is the one wot Richard says!
  10. #8
    Jul 2006
    7,829
    1827
    5505
    Quote Originally Posted by EmanuelGoldstein View Post
    It's a little counterintuitive, but hydrostatic is pressure fed, hydrodynamic is when the movement of the mechanical elements induces a lubrication wedge between bearing surfaces.
  11. Likes Lurk, cyanidekid liked this post
  12. #9
    Sep 2010
    Oklahoma City, OK
    4,573
    790
    1881
    My mnemonic is that hydrostatic is pressure fed as a way to keep static pressure.
    Quote Originally Posted by Forrest Addy View Post
    Damn glad to see you around, Forrest!
  13. Likes Lurk, rklopp, cyanidekid liked this post
  14. #10
    Jan 2005
    The Netherlands
    5,852
    280
    1511
    Isn`t the development in tooling dictating linear ways ???
    Peter
  15. #11
    Aug 2007
    Wisconsin
    2,081
    1116
    946
    Application Specific.
    Do you need a robust machine to take heavy cuts.
    Or a fast light duty machine to lay carbon fiber.
    Kind of like on Saturday morning, you would like a pick up truck to take yard wast to the dump, but then Saturday night you would like a sports car to go out and chase the ladies, or dudes......
  16. #12
    Apr 2006
    missouri
    220
    86
    59
    Quote Originally Posted by Peter from Holland View Post
    Peter
    that's an interesting thought. or could it be that since linear ways are becoming more prevalent, that cutting tool design is being optimized for use on machines with linear ways to take advantage of the advantages of those way systems and to minimize the disadvantages of them.
  17. Likes Derek Smalls liked this post
  18. #13
    Jul 2009
    Peoria, IL
    11,736
    51
    8988
    The best and biggest names in machine tools still use a mix of both. Mazak is entirely linear guides as far as I know. But Okuma uses box ways on the lathes and linear guides on the mills. Similar for Mori Seiki.
    Some companies like Doosan use box ways as a selling point claiming rigidity. Others like Brother use linear ways using speed as a selling point.
    I think we will see both for years to come.
  19. Likes cash, Richard King, Paolo_MD liked this post
  20. #14
    Sep 2010
    Oklahoma City, OK
    4,573
    790
    1881
    Quote Originally Posted by ewlsey View Post
    ...horses for courses.
  21. #15
    Sep 2009
    barcelona, spain
    2,401
    540
    1438
    Imo,
    Linear guides are taking over, eventually accounting for most-all typical contact-bearing machine tool uses.
    I believe linear guides are 90% of machine tool ways, in 2019, by new machines made in units.
    I doubt any manually scraped contact surfaces in machine tools will be relevant in 10 years, == 2029.
    Machine-ground surfaces similar to todays scraped surfaces might be used in some very specialty apps by 2029.
    Clar(ification):
    I did not belittle the scraping skills and quality and results achieved here by many in PM in many cases, at all.
    I just opined that it will not be commercially relevant past maybe 1(-2)% or less of cases, by 2029.
  22. Likes Richard King, scraper liked this post
  23. #16
    Aug 2010
    Medina OH
    2,009
    187
    935
    The added benefit of the linear ways is the comparatively lightning fast rebuild time.
    That is one of the reasons I bought a Brother.
    Don’t get me wrong, I learned scraping to rebuild some of my old machinery, and I am a rank amateur, but it takes FOREVER comparatively.
  24. Likes Richard King, Paolo_MD liked this post
  25. #17
    Apr 2006
    Manchester, England
    8,433
    1247
    5378
    Another vote for a well designed hydrostatic system.
    Regards Tyrone.
  26. #18
    Jan 2005
    The Netherlands
    5,852
    280
    1511
    Perhaps linear motors will take over
    Do these have seperate ways BTW ??
    Peter
  27. #19
    Jul 2006
    7,829
    1827
    5505
    Peter
    So far the linear motors I've seen just provide propulsive force, not axis direction or stability. So they've using linear rails to provide that.
    Now in theory they should be able to do both, but the force required to be stable in all six axis while under cutter load or movement directive would likely be energy prohibitive, unless we got a practical superconductor for the drives.
  28. #20
    Jan 2007
    8,089
    414
    6677
    Peter
    Yes separate and in bigger sizes they do not like box or conventional ways due to huge attraction force which will clamp down these type setups.
    Bob
