Hi All,
I am rebuilding an English Eagle manual surface grinder and it has some significant wear on the table. I wanted to get your opinion on whether it is too much wear and how to approach the rebuild.
The second photo shows where the table has been worn. The main ways have worn right down so there is no more clearance in the middle away from the ways. But even this has started to wear down, as shown by the ringed parts.
I haven't yet measured the wear, but given all the factory clearance has been used up and then even more, it looks in the order of 2-3mm. That's about 100 thou.
I've practised scraping with dimensions 1/10 of these values and I'm a little worried about the amount of wear in this table.
I know I can put it on the mill and get back the clearance and rough out the ways with the mill and then scrape in the difference.
But my main question is to check if this sounds like just too much wear.
Craig
Craig
