where to find high precision lead screw?
Results 1 to 10 of 10
    Jun 2006
    SWEDEN
    513
    485
    132
    Default where to find high precision lead screw?
    Hi,
    As the title implies, any hints or tips on where to find suppliers for lead screws? Not the average rolled stock but good enough for use on a lathe for threading, I recall 0,03mm/300mm, in the ballpark of... 0,0006inch/foot, pitch accuracy.
    Jul 2006
    Hillsboro, New Hampshire
    7,763
    1813
    5461
    Quote Originally Posted by Lumberjack View Post
    Hi,
    This company claims to offer precision ground lead screws: Acme and Lead Screws but no idea of cost or "lead" time. Contact them and see what they say.
    Jul 2005
    Cottage Grove, MN 55016
    7,659
    4120
    4566
    call these guys and ask them how accurate Green Bay Manufacturing
    Jul 2007
    UNITED KINGDOM
    4,857
    2605
    2364
    Halifax Rack & Screw in the UK do ACME and Trapezoidal screws in .06mm/300mm standard from stock. I don't know if they do .03mm/300mm to order. It might be worth contacting them.
    Jun 2016
    New York
    1,569
    881
    677
    Quote Originally Posted by Richard King View Post
    they list class 2G rolled threads, which is +-.25 mm on 25, +-.010 on an inch, (on the pitch dia.) according to a quick search, so not so precision.
    Jul 2005
    7,659
    4120
    4566
    Quote Originally Posted by cyanidekid View Post
    He can call them and ask if they make specials or know someone who does.
    Jun 2006
    SWEDEN
    513
    485
    132
    Thanks for the input guys, I´ll contact them.
    Cheers
    GERMANY
    2,767
    1752
    974
    Since you are in Sweden it might be easier to buy from Germany. If you look on German Ebay, just search for "Trapezgewindespindel" and "Gewindespindel". Some of the vendors list the accuracy of the lead (I think that I remember seeing 30 microns in 300mm for precision ones, and a factor of ten worse for normal ones). For other vendors you may need to contact them to ask.
  9. Likes Richard King, Lumberjack liked this post
  10. #9
    Jul 2014
    GERMANY
    68
    36
    45
    In Germany there are enough sources for ACME-threads, but less who grind the threads.
    In stock they have rolled finished and whirled finished threads. Ground finished threads normally will be manufactured as they are ordered.
    Rolled finish:
    cheap; lead tolerance: 0,1 mm / 300 mm; straightness: 0,3 mm / 300 mm
    Whirled finish:
    cheap; lead tolerance: 0,05 mm / 300 mm; straightness: 0,3 mm / 300 mm
    Ground finish has best lead tolerance, but really expensive.
    This company in the netherlands has whirled finish with 0,05 mm / 300 mm in stock:
    Trapezoidal Thread spindles - Trapezoidal Thread
    This company has whirled finish, too and a distributor in denmark:
    Trapezgewindespindeln & -muttern | WMH Herion
    Distributor in denmark: Zero-Max A/S |
    Mädler is a distributor in germany who sells ACME-thread with whirled finish in 0,03 mm / 300 mm:
    Trapezgewinde- und Kugelgewindetriebe - Madler Webshop
  11. Likes ballen, Lumberjack liked this post
  12. #10
    Jul 2014
    GERMANY
    68
    36
    45
    Rolled finish:
    Whirled finish:
    Mädler is a distributor in germany who sells ACME-threads up to 0,03 mm / 300 mm (ask for this accuracy before ordering!):
  13. Likes ballen, Lumberjack liked this post
