Winona Van Norman Surfacer Gearbox Lube?
Likes Likes:  0
Results 1 to 5 of 5
    Jul 2019
    Default Winona Van Norman Surfacer Gearbox Lube?
    I'm nearing the end of a full restoration on a 1985 Winona Van Norman SM-2000 cylinder head and block resurfacer. The table is driven by a rack and pinion setup, with an electric motor transmitting through a right angle gear box. I currently have the gearbox apart to replace the bearings and examine the status of the internals in general. It is a simple unit with a steel worm gear and a brass worm wheel. Now that I would like to reassemble the unit, I need to determine the correct grease for the bearings and gear oil for the gears.
    It's relevant that the grease and gear oil share the same area inside the gear box... the splash lubrication of the gear oil must spray the grease covered bearings continuously.
    So now to my question, I'm concerned about finding the correct oil and grease that will not damage the bronze worm wheel. I have the owner's manual for the machine (no service manual is available). It states that the gearbox uses SAE 80 gear oil but nothing more specific and of course, no mention of grease for the bearings because they don't expect the user to disassemble the box.
    I've read about extreme pressure gear oils having additives that actually form a protective boundary on the teeth of the gears and that boundary is stronger than the brass. Therefore, instead of the boundary layer alone shearing off each with each round of meshing teeth, it actually takes brass with it. I've read that some GL-4 and all GL-5 oils have these additives. Of course, I've also read they NO LONGER have these additives and are now safe for bronze. Hard to know what to believe...
    Also need to know if there is a grease that is good for packing the bearings with but safe for the bronze worm wheel because as I said, the grease and gear oil share the same real estate.
    Thanks!
    Jan 2002
    Upstate NY -In the Flats next to the corn fields
    8,923
    1421
    2371
    This.............................................. ..................
    Mobil Mobil SHC 630, Circulating, ISO 220, 1qt 123000 | Zoro.com
    Jul 2019
    Quote Originally Posted by dkmc View Post
    That looks promising, thanks. If I look through the chart here: https://www.mobil.com/English-US/Indust ... 600-Series it appears that SHC 627 is roughly equivalent to SAE 80 or 85 and all the 600 series are rated a 1B on the ASTM D130 copper corrosion test which means they have a very very minor effect.
    Any advice on a bronze compatible grease for the ball bearings?
    Jan 2002
    8,923
    1421
    2371
    I'd call as far as possible up the ladder at Mobil labs, and ask, they should be able to recommend something.........
    Jul 2005
    Cottage Grove, MN 55016
    7,508
    4066
    4489
    Give these guys a call and ask them.
    SURFACER LUBRICANTS
