oughtsix
- Sep 1, 2009
- oregon USA
I found an Enco 8x36 mill for $2600. I talked to the seller and he is willing to come down to $2300. Original owner, circa 1994, great shape, comes with power X feed, Chinese vice and a few R8 collets. etc. Here are the pics... what do you guys think?
My gut feeling is it is a good deal... and a good size for my shop. I don't have room for a full size mill.
Enco 100-1525 = Grizzly G6760 = Jet JVM-836. Parts are said to be interchangeable.
Here are the Jet 836 specs... the Enco "Might" be 10 speed but might be 5 speed. Enco weight is reported to be 1600lbs - 1800lbs.
Specifications
Style (Type) Step Pulley R8
Powerfeed X-Axis
Spindle Taper (In. x TPI) R-8
Table Size (L x W) (In.) 7-7/8 x 35-3/4
Quill Diameter (In.) 3-3/8
Number of Spindle Speeds 5
Range of Spindle Speeds (RPM) 240 - 1,550
Quill Down Feed Rates (IPR) .0015 - .003 - .006
Spindle Travel (In.) 5
Head Movement (Deg.) 90 R & L
Max Distance Spindle to Table (In.) 13-3/4
Distance Spindle to Column (Max.) (In.) 15-3/4
Distance Spindle to Column (Min.) (In.) 5-1/4
Collet Capacity 1/8 - 7/8
Table Longitudinal Travel (In.) 22-1/4
Table Longitudinal Travel With Powerfeed (In.) 18
Table Cross Travel (In.) 9-1/2
T-Slots Number and Size (In.) 3 and 5/8
T-Slot Centers (In.) 2-1/2
Work Table Weight Capacity (Lbs.) 500
Travel of Knee (In.) 14
Travel of Ram (In.) 10-1/2
Motor (HP) 1-1/2 HP, 115/230V, 1Ph
Overall Dimensions (L x W x H) (In.) 55 x 52 x 78
Weight (Lbs.) 1,617
Specifications
Powerfeed X-Axis
Weight (Lbs.) 1,617
