Roland MDX-540 CNC With Safety Box + End mill + PC + Monitor Touch. Price: 13500
For any questions, customized shipping cost for your address, custom pictures, or demostration video, just ask
[email protected]
Items included in the sale:
- Roland MDX-540 milling machine
- Roland handy panel
- Roland tool sensor
- Roland safety cover (blue box in the picture)
- Roland original collets 4mm 6mm and 10mm size
- Nut and nut wrench
- Some end mill (see picture)
- HP PC with Roland panel software installed
- Professional touch screen with side USB port
MDX-540 Milling Machine Specifications
MODEL MDX-540 MDX-540S
Usable Materials Plastic, resin, wood and non-ferrous metals
XYZ-Axis Travel 19.6(X) x 15.7(Y) x 6.1"(Z)[500 (X) x 400 (Y) x 155 mm (Z)]
Loadable workpiece size with optional rotary axis (ZCL-540) * 7.0” Diameter x 14.6” Length [177.8mm Diameter x 370.8mm Length]
Actual milling area is smaller
Distance From Spindle Nose to Table Maximum 10" (254mm)
Table Size 21.7(W) x 16.5"(D) [550(W) x 420mm (D)]
Loadable workpiece weight At acceleration of 0.2G: maximum 26lb (12kg), 0.1G: 44lb (20kg), 0.05G: 44lb (20kg)
XYZ-axis drive system AC servo motor, 60W AC servo motor, 80W
Operating speed Maximum 295ipm (7.5m/min)
Acceleration 0.2G, 0.1G, 0.05G
Software resolution RML-1 mode: 0.0004"(0.01mm ), NC-code mode: 0.00004" (0.001mm)
Mechanical resolution 0.00004” (0.001mm)
Positioning accuracy +/-0.004"/12"(+/-0.1mm/300mm), under no-load conditions
Repeat accuracy +/-0.0019"(+/-0.05mm), under no-load conditions +/-0.0008"(+/-0.02mm), under no-load conditions
Origin reproducibility (when the power is switched on/off) +/-0.0019" (+/-0.05mm) +/-0.0008" (+/-0.02m)
Spindle motor DC brushless motor, maximum 400W
Spindle speed 400 to 12,000 rpm; 400 to 3,000 rpm for positioning and centering
Tool chuck Collet method, maximum tool diameter: 0.4" (10mm)
Control command sets RML-1 and NC codes
Interface USB (compliant with Universal Serial Bus Specification Revision 1.1)
Power supply Voltage and frequency: AC 100 to 120 V/220 to 240 V +/-10%, 50/60 Hz
Required power capacity: 7A (100 to 120V)/4A (220 to 240V)
Power consumption Approx. 700W
Acoustic noise level During operation (no cutting): 65dB (A) or less, during standby: 40dB (A) or less (according to ISO 7779)
Dimensions Width x depth x height: 29.3 x 37.6 x 33.8Z" (745 x 955 x 858mm) Width x depth x height: 30.1 x 37.6 x 33.8Z" (765 x 955 x 858mm)
Weight 225lb (102kg)
Operating temperature 41 to 104F (5 to 40C)
Operating humidity 35 to 80% (no condensation)
For any questions and custom pictures, or demostration video, just ask.
[email protected]
