Speedaire Electric Air Compressor 4ME98 - $950 or Best Offer
Likes Likes:  0
Results 1 to 1 of 1
    Jan 2016
    Default Speedaire Electric Air Compressor 4ME98 - $950 or Best Offer
    Contact: Devan Flores [email protected]
    Electric Air Compressor, Compressor Type Tank Mounted, Number of Stages 1, Lubrication Type Splash Lubricated, 5 HP, Max. Pressure 140 psi, Free Air CFM @ Max. Pressure 14.2, Voltage 208-230/460, 3 Phase, 13.4-13.2/6.6 Amps, 60 Hz, Tank Size 60 gal., Tank Type Vertical, Base Model, ASME Tank Yes, (F)NPT Outlet 3/4 In., Cylinder Material Cast Iron, Powder Coated Finish, Control Pressure Switch, Motor Type Open Dripproof, Overall Length 23 In., Overall Width 31 In., Overall Height 71 In
    Finish : Powder Coated
    Free Air CFM @ Max. Pressure : 14.2
    HP : 5
    Includes : Manual Drain Valve, Oil Sight Glass, Pressure Gauge, Pressure Safety Valve
    Item : Electric Air Compressor
    Number of Stages : 1
    Phase : 3
    Tank Size : 60 gal.
    Tank Type : Vertical
    Control : Pressure Switch
    Cylinder Material : Cast Iron
    Hz : 60
    Motor Type : Open Dripproof
    Overall Height : 71"
    Overall Length : 23"
    Overall Width : 31"
    Pump RPM : 950
    Voltage : 208-230/460
    dBA @ 3 Feet : 85
    Standards : ASME, UL/CSA, California Code 462(L)(2), UL1450
    Compressor Type : Tank Mounted
    Off Pressure Switch Setting : 140
    On Pressure Switch Setting : 110
    Amps : 13.4-13.2/6.6
    Max. Pressure : 140 psi
    (F)NPT Outlet : 3/4"
    Pump Oil Capacity : 16 oz.
    Lubrication Type : Splash Lubricated
    ASME Tank : Yes
    Compressor Package Type : Base Modelimg_6761.jpgimg_6773.jpgimg_6775.jpgimg_6776.jpgimg_6777.jpg
    Last edited by tyrexmarketing; 01-06-2016 at 09:11 AM. Reason: Contact Information
