Brown & Sharpe No. 2 and 2B Surface Grinder manual.
Results 1 to 6 of 6
    Dec 2010
    Idaho, USA
    500
    49
    Default Brown & Sharpe No. 2 and 2B Surface Grinder manual.
    Here's a project for someone. Raw scans of a Brown & Sharpe No. 2 and 2B surface grinder manual. Needs cropped, cleaned up, changed to greyscale, OCR and editing to make it better suited for printing and to reduce size a lot.
    Good enough as-is to be able to read how to use and maintain and maintain / repair the machine. It also covers various accessories.
    B&S No. 2 pages-4-6-52 - Download - 4shared - Gregg Eshelman (Better scans of those 3 pages. Foreword is still bad but could is readable enough to type it in.)
    B&S No. 2 pages 1-14 - Download - 4shared - Gregg Eshelman
    B&S No. 2 pages 15-25 - Download - 4shared - Gregg Eshelman
    B&S No. 2 pages 26-40 - Download - 4shared - Gregg Eshelman
    B&S No. 2 pages 41-56 - Download - 4shared - Gregg Eshelman
  2. Likes omrc7771, shawn_t, michiganbuck liked this post
  3. #2
    Mar 2013
    Oshkosh, Wis. [email protected]
    871
    511
    303
    Thanks a million!
    May 2006
    Phoenix
    5
    Default This manual will come in handy
    I found a treasure trove of unique machines and machine tools so I put all my own machines on eBay and setting up the new to me machines. One of them is a Brown & Sharpe No 2 Surface Grinder. It looks intact, has the original paint, shows no sign of wear. It has a tag: " Picatinny Arsenal U.S.P. 2401. It has the original 18 1/8" model 618 magnetic chuck. The original motor tag says GE 440 volt 3 phase 1 1/2 HP 1735 full load RPM but it has been replaced with a single phase motor.
    The manual I found in this thread is invaluable as I have no experience with these machines and want to make sure I do a proper restoration.
    Jun 2008
    New England
    201
    7
    44
    Mar 2014
    United Kingdom
    25
    Hi Shawn, I am also restoring a # 2L and need to replace the rack due to lack of teeth! I know the tooth pitch is DP10 , but do you know the PA (mine is too worn to tell the difference between 14.5 deg and 20 deg by eye)
    Jul 2004
    Houston, TX USA
    29,471
    Quote Originally Posted by stormbird View Post
    Shawn last visited forum in February
