goodgollyjosh
- Apr 20, 2015
- San Antonio, Texas
Howdy from Texas guys,
I am glad I found this forum, it looks chock full of good info. I am looking forward to learning and chatting with y'all. I am a hobby machinist, my trade is engine building so the machining came a bit out of necessity. My familiarities are more towards automotive machining equipment but have done some manual lathe and mill work in the past. Here are a couple of photos of some old machines I have picked up over the years.
The one on the right is a Southbend lathe that appears to be out of the 30's as best I can tell. It was stamped by the War Production Board so it seems it went through WWII at the very least. It has auto-feed and seems to work well enough. It rides on bushings that I oil every now and then.
The one on the left is a Kwik-Way valve grinding machine/tool and die cutter from 1928/29. It came with a lot of attachments, most of which I do not know how to use. I was fortunate to download the last known manual from Kwik-Way's website. It seems to work equally good. I ground some valves on it the other day and the finish was quite nice. I like the old leather belts, it sounds a bit like a sowing machine.
Cheers!
Cheers!
