Picked up this old Walsh Screw Press a while back
Likes Likes:  0
Results 1 to 6 of 6
    Aug 2018
    Michigan
    7
    Default Picked up this old Walsh Screw Press a while back
    Bought this at a auction when nobody else wanted it lol
    Aug 2015
    Illinois
    1,458
    1062
    631
    From the heavy wheel rim and the two handles projecting downward from it I would say you bought a Fly Press. An extremely coarse thread would confirm that.
    Aug 2012
    California, Central Coast
    4,044
    2227
    1589
    Looks good congrats
    Could be a fly press or just a screw press. Can you show pics of the threadded screw? Does the ram/screw stay up by itself or does it spin down on it own? Both have advantages.
    Aug 2018
    Michigan
    7
    Default here is a better photo of the Walsh Press
    I hope this helps
    Aug 2012
    4,044
    2227
    1589
    That helps. It looks like the screw is holding up the upper platen. This makes it a screw press instead of a fly press and you can use it to clamp things and hold them (like a giant c-clamp) Where a fly press would be more of blend between pressing and hitting due to the fast advance of the ram. This makes fly press good for forging metal. Fly press can not hold pressure like yours can.
    Jan 2009
    Missouri
    101
    151
    30
    But the handles and apparent twin pitch lead of the thread are confusing. Increased pitch reduces power, while speeding up travel.
    Screw press also good for straightening, with advance easier to monitor than rack and pinion or hydraulics.
    This is how precision barrels are straightened, but screw is from below. The barrel maker looks down the bore 'aimed' at a wire hanging in front near a window or front light. Laid in vee blocks and rotated, the narrow, defined shadow points out ANY deviation from straight; whether curve or kink.
