Portable Generator
Likes Likes:  0
Results 1 to 3 of 3
    Apr 2017
    Wisconsin
    Default Portable Generator
    I want to buy a portable generator for my garage, i have 3 welding machines and other heavy machinery there, which generator should be best for this purpose?
    Mar 2012
    Geilenkirchen, Germany
    2,211
    1357
    1124
    Quote Originally Posted by aaronrodg View Post
    No one can answer such a vague and incomplete query. You have to state your maximum load, its running environment, desired fuel type and expected run time. However, from your very vague description, I suspect no PORTABLE generator will be adequate.
    Oct 2012
    Virginia
    10,268
    5843
    4620
    Quote Originally Posted by steve-l View Post
    Semantics? Megawatt units in trailers are "portable" if one has a K-Wopper or Peterbilt tractor to "port" them.
    Does sound as if the practical minimum, even ONE welder, if expected to be stable, is a ten KVA "continuous" rating.
    I get by with an MEP-803A, 4-cyl Lister-Petter motored liquid-cooled Diesel @ 1800 RPM. MIL_SPEC units being generally long-lived and very, very conservatively rated.
    A Harbour Freight 3600 RPM air-cooled gasoline or LPG engined unit might get you by "for a while", but many years LESS of a "while", and with far lower stability under changing load.
    Gen sets built WITH welders, BY the welder-makers are a special case. Lower KVA needed as they were tuned to the specific load. Do not ass u me that a HF or similar of same-nameplate rating is "equal".
    2CW
