Is this South Bend lathe still a good buy?
Results 1 to 9 of 9
    Apr 2019
    5
    Default Is this South Bend lathe still a good buy?
    Hello!
    I am planning to buy this South Bend lathe.
    The seller says that the back gear is already worn out. Thus, the lathe cannot run at low speeds.
    I am just a beginner at machining. I want to learn lathe machining as a hobby.
    Is this lathe still a good buy?
    received_2176048082432989.jpgreceived_2446411855417757.jpgreceived_1904691306303166.jpg
    Would installing an inverter and a three-phase motor solve the issue of the broken gear?
    Thank you.
    Cheers!
    Jan 2014
    Coventry RI
    1,152
    1388
    923
    I'm not sure what the seller means by "worn out". The usual problem with the back gear is broken teeth on one or more of the gears in that system caused by misuse, NOT wear. He may mean that the spring loaded plunger which keeps pressure on the back gear engagement cam is missing or not working. This will cause the back gear to work out of engagement while using it. Or, the gear assembly may not have lubed correctly and is now a bit loose on the shaft it rides on.
    Obviously, I can't tell the condition of the back gear from the above pics, but it does appear the back gear shaft is in place. All these parts are easily replaced and can be found on ebay or from folks here.
    As long as the rest of the machine is in good shape, I'd buy it and repair the back gear, it should not be a difficult nor expensive repair.
    Using a VFD to get variable speed is cool but not good for very low motor rpm like you'd need with no back gear. You loose a lot of torque that way.
  3. Likes steve-l, tim9lives liked this post
    Sep 2010
    moscow,ohio
    6,337
    647
    2110
    It is a South Bend 10K....how can anyone know if it's a good buy without knowing the price??
    Jul 2004
    Houston, TX USA
    30,860
    Good pub to digest
    http://campkahler.com/files/How_to_R...he_SB_1of2.pdf
    http://campkahler.com/files/How_to_R...he_SB_2of2.pdf
  6. Likes raselo, rsk4today liked this post
  7. #5
    Apr 2019
    CANADA
    Alberta
    13
    I think that as a beginner you should not buy a lathe in unknown condition, especially since the one you showing seems in poor shape. As a beginner you you will have enough challenges besides dealing with lathe related problems. And there is no shortage of good machines at very reasonable prices.
  8. Likes michiganbuck liked this post
  9. #6
    Apr 2019
    5
    Thank you very much for these resources. These are really helpful.
  10. #7
    Apr 2019
    5
    "It is a South Bend 10K....how can anyone know if it's a good buy without knowing the price??"
    I apologize for this. The seller wants 650USD for it.
  11. #8
    Sep 2010
    moscow,ohio
    6,337
    647
    2110
    As long as you can verify all functions work, going through the settings and turning the chuck by HAND, then I would say you can't get hurt at 500 for your area.....don't power it until you can give it a proper wipe down and oiling.
    You can check the motor spins up, but do it with the belt slack and the reverser in the neutral position, only very briefly just to see if the motor runs.
    Good luck, if it works out you will have a decent first lathe.
  12. #9
    Mar 2020
    GERMANY
    15
    I have couple of WWI photos of my grandfather, and would like them colorized. Do any of you know a reputable person or company that does this? Thanks Ken
