George, Direct Reduction is a process to take iron ore and make it into iron.
It uses natural gas most commonly, but other fuels are possible.
It does not require coke or limestone.
The old style blast furnaces are 19th century tech.
As I mentioned, Direct Reduction was invented in Sweden in the 1930's, and has been used on an industrial scale, all over the world, ever since. Currently there are about 67 million tons of iron being made this way.
After the iron is refined by Direct Reduction, it goes into an Electric Arc Furnace, and is made into steel by adding the desired ingredients for whatever alloy you want. These EAF's are usually at the head of a continuous casting line, so it can then be rolled into slab, and then plate, bar, or section.
These EAF/continuous casting lines are what Nucor uses in its 20 or so North American mills, and right now virtually all of em remelt scrap. 25 Million tons or so a year.
So at this new mill Nucor has a choice, to process the iron ore- either a traditional coke/limestone blast furnace, or a DR system. Both have been proven, are in common use worldwide, and work just fine.
The choice is based more on local economics, availability of coke versus natural gas, and local laws about emissions.
In the places where DR is most common, coke is expensive, and gas is cheap.
Here is a brief description of the process at the Western Australia mill-
http://www.midrex.com/uploads/documents/Fines to Slabs1.pdf
Pelletized ore is made into iron, then fed to an EAF, then rolled.
Oregon Steel, in Portland, set up DR mill in the USA in 1969.
This is not that new.
Not much of it is done in the USA right now, I guess, but ESSAR, the Indian company, has broken ground on their DR mill in Minnesota.
There is a big mill in Mexico doing it, along with many more around the world.
http://www.worldsteel.org/?action=stats&type=irondr&period=latest
