China's "artificial sun"-------ot
Results 1 to 17 of 17
    Oct 2005
    western washington state
    3,446
    2120
    3341
    Default China's "artificial sun"-------ot
    China's tokamak has been operational since 2006
    it recently birthed plasma of 100 million degrees C
    YouTube
    China's 'artificial sun' reaches 100 million degrees Celsius marking milestone for nuclear fusion - ABC News (Australian Broadcasting Corporation)
    Nov 2017
    Kansas
    244
    58
    109
    PV=nRT says what? Wonder how long it takes them to ramp up to that and how do they control the P?
    Nov 2017
    Kansas
    244
    58
    109
    Ok so a 360tn reactor goes long way and the n has to be stupid small, but I bet the real story is the the supporting equipment. I have toured a 10Mw fission reactor and it was pretty unimpressive even with low thermal loading.
    Jan 2016
    New Jersey
    109
    52
    49
    Quote Originally Posted by Aejgx6 View Post
    Most experimental fusion reactors do 1-5 shots a day, but the biggest factor is cooling time for everything. Plasma facing components and electromagnets in particular.
    Also, P is actually very low, there's not a whole lot of fuel in the reactor, and everything starts at fairly low vacuum. I'm not sure what EAST runs off the top of my head, but probably in the low double digit MW range.
    EAST has set some pretty important records, the Chinese are putting serious effort into it.
  5. Likes JHOLLAND1 liked this post
    Sep 2015
    Tennessee
    462
    238
    355
    As said, very very little n, and the 3.5 Tesla field helps (a lot)
    Nov 2017
    Kansas
    244
    58
    109
    Quote Originally Posted by Rewt View Post
    forgive me I studied chem..
    Does the magnetic containment reduce the effect P on the vessel? Can you base a design around that, and how would that apply to a critical failure? Say you lose vacuum and super heat some fly shit left on a seal?
    Jun 2012
    Michigan
    9,471
    3230
    3395
    Currently being built in southern France with collaboration from 35 nations including China, ITER is set to be the first experimental fusion device to produce net energy, producing 10 times more energy than the power required to run it, according to the project website.
    If successful electric cars will be practical.
  9. #8
    Nov 2018
    CANADA
    British Columbia
    153
    27
    102
    The ABC News article, like much of the media reporting, shows the ignorance of science and more hype than any realistic information. This is a piety, as the science behind plasma confining, heating and fusion is certainly exciting, but any usage of fusion as a source of energy is still many years in the future...if ever. The Tokamak type fusion systems experiments have been conducted since the 50s with dozens of facilities built (to the tune of many billions). Some interesting results were obtained and a lot of experience gained - mostly in other fields (superconducting magnets, lasers, RF heating, etc) that served the main experiments. However all the system use a huge amount of power to produce a very short lived fusion. We are still very far away from a system that will generate equal or more power than used to keep the fusion going.
  10. #9
    Jul 2011
    East Yorkshire UK
    327
    774
    267
    Quote Originally Posted by michiganbuck View Post
    I think they were all intended to produce more power than they consumed, the fact that they all have so far failed to do so, and have cost an absolute fortune to build is an indication of what a blind alley nuclear fusion is. If all the fusion research money had gone into renewables such as wind, solar and tidal, we would have no need for ANY expensive nuclear stations.
  11. #10
    Jul 2012
    Washington
    2,470
    966
    998
    Probably the problem with renewables funding is they can't be weaponized.
    michiganbuck, you got a link to that website?
  12. #11
    Jun 2012
    Michigan
    9,471
    3230
    3395
    Had the web site a time ago ..let me look for it..
    Every energy is a give and take. it took so long to make all the coal and when it is gone, it is gone. Same with Gas, natural gas and fire wood.
    Plants and trees make oxygen so with a solar panel taking sun that small bit of place for a plant to grow is lost. Same with side walks roads buildings and the like all take up space.
    I don’t know what is the giveaway is for nuclear energy, space for all the hot stuff and some water that must be off use for a thousand years perhaps.
    Or what for this new sun energy…
    No matter, likely we will blow up the planet having a stupid war before we run out of things.
    Found It:
    What is ITER? .....The energy project in France.
    ITER's First Plasma is scheduled for December 2025
    likely Russia does not/will not like losing top dog position in selling energy.
    Yes likely the world would be better off if we all still lived in a Tipi.
  13. Likes DavidScott liked this post
  14. #12
    Mar 2011
    Denver, CO USA
    10,106
    58
    5668
  15. Likes DrHook, TeachMePlease liked this post
  16. #13
    Mar 2011
    Denver, CO USA
    10,106
    58
    5668
    Yes.
    Because the working fluid is a plasma a magnetic field can be used to contain it rather than a physical bottle.
    Thus the P can be much higher.
  17. #14
    Mar 2011
    Denver, CO USA
    10,106
    58
    5668
    Quote Originally Posted by DavidScott View Post
    Yep.
    Our nuclear designs are developed around making nuclear fuel for bombs.
    There are much safer and smaller systems, and have been for decades, but the don’t make weapons grade waste.
  18. #15
    Jun 2012
    Michigan
    9,471
    3230
    3395
    QT: [If successful electric cars will be practical.]
    If it (ITER) makes 10% more energy than it uses then there might be energy for a lower price the fossil fuel so then making electric better/good/OK?
    but don't hold your breathe because many things that seem free/good are not.
    And it may cost so much to make or maintain that a profit or savings may never be made.
  19. #16
    Jan 2016
    New Jersey
    109
    52
    49
    Quote Originally Posted by hermetic View Post
    TFTR was the last magnetic confinement reactor built with the expectation to reach break even (outside of mostly specious commercial attempts). Huge amounts of knowledge were gained about plasma stability that pushed research towards inertial confinement (the NIF facility at Lawrence Livermore was I believe planned to reach break even, but now they believe it's off by a factor of three or so). That technology is highly relevant to weapons (it's primarily used to study reactions
    to optimize fusion bombs) and has the budget to show for it. ITER is planned to hit something like 20% of break even (which is a huge stride in its own right).
    the fact that they all have so far failed to do so, and have cost an absolute fortune to build is an indication of what a blind alley nuclear fusion is.]
    More powerful superconducting magnets will hopefully shrink the size and related capital expenditures in the future, but as far as investments go there actually has not been a whole lot in fusion, and it's a whole lot harder than drilling and waiting for stuff to come up. $25B over more than three decades from six large countries and a conglomerate of most of the highest GDP countries behind the first six -- and that money puts to shame the amount that has been spent over the years.
    Wind, solar, and tidal all have environmental trade offs that nuclear fusion would not require, and the real application of fusion is in building space ships for long term travel.
    I've been wondering if I should write a book on the history of fusion research (I'm not sure I'm really an expert, but I do work at a fusion research lab), as it seems there is far more misinformation in the public space than properly communicated scientific findings. But more interesting/rewarding work seems to get in the way...by the time I retire I hope we have fusion (I definitely fall on the young end around here).
  20. #17
    Jun 2012
    Michigan
    9,471
    3230
    3395
    QT: [I've been wondering if I should write a book on the history of fusion research ]
    Perhaps it would be difficult to write such a book on a level low enough that I might understand.
    Wind and solar considering the maintenance and other factors are more costly than most people think.
