GeneH
Stainless
- Apr 11, 2006
- Pennsylvania
I dabble in embedded controllers, and what embedded controller person doesn't at times think about their car's engine computer?
Ran across this online, figured some would be curious to know how flexible "flex" fuel cars can be...
"Flexible fuel vehicles use a sensor to determine the percentage of ethanol in the fuel mix (which varies not only with the season and location, but also with the relative amounts of E85 and gasoline in the tank at fill-up) and adjust the fuel injection and timing to suit the fuel. Understanding these sensors is the key to using E85 with MegaSquirt."
"The frequency of the signal indicates the ethanol percentage. The output frequency is linear with respect to the percentage of ethanol content in the fuel.
50 Hertz indicates 0% ethanol, and 150 Hertz indicates 100% ethanol."
"The processor inside the sensor is capable of some self-diagnosis. An output frequency of 170 Hertz indicates either that the fuel is contaminated (or contains methanol which it should not), or that an internal sensor electrical fault has been detected. Certain substances dissolved in the fuel can cause the fuel to be contaminated, raising the output frequency to be higher than the actual ethanol percentage should indicate. These contaminates may commonly be water, salt, methanol, or some other substances."
Well, well, so it's "Bio-mass or bust", huh? No Methanol from coal or paper waste or what have you. Only what the Greens decided... or maybe it's an engineering compromise. Aint' sure which.
In any case, your "flex fuel" car won't run on Methanol without some modification. Too bad.
From http://www.megasquirt.info/flexfuel.htm
Gene
Gene
