Looking for Recommendations for a Machine Shop located in China
Page 1 of 2 12 LastLast
Results 1 to 20 of 33
    Mar 2018
    Default Looking for Recommendations for a Machine Shop located in China
    Hi, first I should say "Hi" to everyone! I'm new to this website and I'm very excited about using it.
    Second, the reason I registered with "Practical Machinist" is I have a small 4"x 4" thin piece of metal I need stamped out and therefore I'm looking for an easy to deal with Machine Shop in China. This would be a small monthly order of possibly 30-40 pieces. Also, I would prefer to deal with a smaller machine shop if possible.
    Since, I've never use a Chinese Company before, I would appreciate any advice and/or recommendations you may have.
    Kind Regards,
    Bob in Spring, Texas
    Sep 2007
    Washington
    4,611
    93
    1132
    Oh Gawd, this is going to be fun to watch
    Regards.
    Mike
  3. Likes Larry Dickman, MattiJ, Rob F., EPAIII, Bobw and 8 others liked this post
    Sep 2008
    Canada
    561
    208
    166
    April 1st is still a few weeks away...
    L7
    Nov 2013
    Utah
    2,584
    712
    1379
    Quote Originally Posted by Antlerbob View Post
    Kind Regards,
    Just out of curiosity, why do you want them to be made in China, as opposed to (wherever) Mexico for example? Why is your question directed to China?
    R
    Jun 2016
    CANADA
    Manitoba
    257
    60
    106
    Quote Originally Posted by Finegrain View Post
    Regards.
    Mike
    Talk about a sucker for punishment. I can't believe anyone would seek help from this forum, when 99% of it's members are against Chinese manufacturing.
    Jun 2012
    Idaho
    2,985
    1623
    1918
    If you are serious,I would contact someone in your State government that deals with trade.
    Sep 2009
    Phoenix,AZ
    1,447
    2302
    327
    Gee where to start ! Stamping infers dies being needed and 30-40 pieces per month ???? If dies need to be made the unit cost will be high in those quantities. Cheap from China ?? Wishful thinking ,try 3000-4000 pieces for reasonable cost.
  9. #8
    May 2017
    FINLAND
    1,140
    303
    542
    Instead of stamping and china you should ask: where I can get 40 pieces of simple sheet metal pieces laser cut in Texas.
    China is alternative when you order 30 to 40 THOUSAND pieces per time..
  10. #9
    May 2005
    AZ
    2,179
    189
    730
    To the OP: Just in case some of the meaning of the arcane commentary above is lost in translation, the gist of it is this: Nobody will have much of a recommendation for a shop in China to do the work you propose, as the Chinese manufacturing sector is the direct competition to many of the members of the Practical Machinist community. If you are dead-set on using a Chinese resource, you may be better served by seeking comment or guidance from the Practical Purchasing Agent community, if such exists.
    The members of this group are generally involved directly in actually making "stuff" on a day to day basis, as opposed to figuring out what OTHER person or persons can do the work for them. The Chinese manufacturers in many cases have taken work directly from many of the members' businesses, via the companies that are looking for the "lowest possible cost". So, not a lot of support here for "let's get it in China".
    That said, as others have noted your quantity requirements are far too low for economical stamping as an initial process. The start-up costs for stamping tooling would be huge relative to your volume, unless you have a part in mind that can somehow fetch a price of many hundreds of dollars per part. In any case, the likely payback for tooling investment for the typical stamped part is probably in the 10,000+ part volume range, depending on part complexity and what you can charge.
    I'll also note that, while doing business in China has gotten easier in the last few years, setting up a reliable supply chain with china as the source is another area where start-up costs can be high; often several trips to suppliers' locations are needed, a middleman may be required, and you need to be prepared to weather quality and delivery issues in the early going.
    YMMV -- my 2 cents' worth for today.
  11. Likes digger doug, Meggab liked this post
  12. #10
    Jan 2007
    Norfolk, UK
    17,127
    12768
    12317
    Mr thinketh the OP taketh the piss.
  13. Likes thermite, BGL liked this post
  14. #11
    Sep 2015
    250
    13
    101
    Why the specific request for a Chinese vendor? You appear to be from Texas, which makes this request somewhat more odd. Are you looking for a foreign vendor because you’ve burned all your local vendors? Or you just don’t believe it when they tell you the cost to set up a high volume production process to produce a small quantity run? Maybe you need to re-think what you are asking and explore other means of producing the parts you are trying to get made.
  15. #12
    Apr 2007
    Pillager, MN
    5,325
    1706
    4592
    Has to be a troll...........no one could be that thick........
  16. #13
    Apr 2004
    Modesto, CA USA
    5,771
    860
    Being that you are in from Texas my recommendation would be to cut them out with tinsnips then stick them with duct tape to posts near a highway. The locals will shoot them full of holes for free. The size and location accuracy will be as good as ones made in China to your specs.
    Bill D
  17. #14
    Jul 2017
    Minnesota
    23
    14
    Quote Originally Posted by Bill D View Post
    Bill D
    lol!!!!!!!
  18. #15
    Nov 2013
    Utah
    2,584
    712
    1379
    Quote Originally Posted by david n View Post
    I wish my life were that boring.
  19. #16
    19,279
    7561
    6097
    Why wish? Just move to Kolding, Denmark.
  20. #17
    Apr 2004
    Modesto, CA USA
    5,771
    860
    Or Modesto, CA. home the the worlds largest winery and cannery. I wonder why they do not put the wine in cans? The movie set in Modesto was about teenagers who wanted to leave town.
    Bill D.
    Modesto, CA. USA
  21. Likes thermite liked this post
  22. #18
    Langley, B.C.
    1,333
    249
    754
    ...stick them with duct tape to posts near a highway. The locals will shoot them full of holes for free. The size and location accuracy will be as good as ones made in China to your specs...
    I near spit my teeth out when I read that. I'm sure that turn-around time would be real short too...
  23. #19
    Mar 2017
    CHINA
    1,813
    1127
    What's the word ?
    Thunderbird !
  24. #20
    May 2010
    New York
    441
    120
    286
