11-23-2020, 11:03 PM #1181
11-23-2020, 11:05 PM #1182
[QUOTE=gustafson;3664277]Lie
the republicans tried to change things, the deadlines stayed the same by and large
so it is all fine and dandy for the President to appoint a major contributor as postmaster, who then, in September, starts slowing the mail down
yeah, that is hones
screw you
Right, and who is disrespecting our system?
trumpski
no one else]
Gus, I haven't quite figured out which axe he is trying to grind but it's definitely out in space somewhere. He might be American but likely first generation if that, based on the Syntax of his speech, much more pronounced in his earlier ramblings. This might explain his rather slanted views. I've put this in the nicest manner I can manage.... I'm sure he'll take it the wrong way
Hodge
11-24-2020, 12:49 AM #1183
11-24-2020, 03:33 AM #1184
11-24-2020, 04:27 AM #1185
And you should broaden your concepts of what an insult is. That you would use "Comrade" so clumsily, in such a simpleton's manner shows your lack of depth.
You're a schoolboy attempting adult conversation, and when failing resorting to rather decrepit insults. You harm any actual point you're trying to make.
JoeE. liked this post
11-24-2020, 04:44 AM #1186
Go back and carefully look at TT's post above mine. My reply had nothing to do with riots. That's the way it shows up when you "reply with quote" to a post where the "reply with quote" wasn't used properly.
Thee are several on here that quite seem to be able to not use it properly.
In your reply to me it appears I made the riot statement. I did not.
11-24-2020, 06:18 AM #1187
11-24-2020, 06:24 AM #1188
11-24-2020, 06:26 AM #1189
I have been misquoted in that manner numerous times and never been such that I castigate them on it. If I were that way I would waste my time. When misquoted I mention it to the person. In the case of CB I went back and put in my quotes.
Many times it is done intentionally to make it look like a person is posting differently on a issue. That is why many will jump to quote it like CG did. It highlights a error and takes it to capitalize on. CG has principles so in a way he mentions it in passing like he begs forgiveness. Many here spend a lot of time on this kind of thing.
11-24-2020, 06:28 AM #1190
11-24-2020, 06:29 AM #1191
11-24-2020, 06:32 AM #1192
11-24-2020, 06:43 AM #1193
11-24-2020, 07:19 AM #1194
Grok
Stranger in a strange Land. by Robert Anson Heinlein
11-24-2020, 07:32 AM #1195
11-24-2020, 07:35 AM #1196
11-24-2020, 07:42 AM #1197
Screwmachine liked this post
11-24-2020, 08:18 AM #1198
11-24-2020, 08:33 AM #1199
11-24-2020, 08:38 AM #1200
