Trapezoidal 22x8 thread need help !!!
Results 1 to 13 of 13
    Nov 2020
    GEORGIA
    5
    Question Trapezoidal 22x8 thread need help !!!
    I am new at work and also new to manufacturing and need to cut internal/external trapezoidal thread 22x8-H7 (D 22mm Pitch 8 mm) on equivalent of 4140 steel and cant find right tool for the job. Could you please suggest either manufacturer or where to look for it. Thank you in advance!
    Jul 2006
    Hillsboro, New Hampshire
    11,751
    2733
    8212
    I've no idea if this is the correct series of thread form you need, but you can try contacting your country's ISCAR representatives to see if it is, or if they have the right insert in a different series.
    https://www.iscar.com/eCatalog/Famil...&GFSTYP=M&fr=1
    Nov 2020
    GEORGIA
    5
    Thanks, I also found this tool but when I choose one with 8 mm pitch related tool holder minimum bore diameter is 40 mm and I need 22mm
    Jul 2006
    11,751
    2733
    8212
    Still worth contacting ISCAR, I believe they can make custom inserts if required.
  5. Likes Fullmetaleng liked this post
    Jan 2007
    Norfolk, UK
    20,912
    16353
    16778
    My thoughts.
    22 x 8 is one hell of a pitch, the helix angle will play havoc with the internal tool, .......not to mention the <>4mm depth of thread, which means the minor dia will be <>14mm ............to get a tool that depth of thread in? .................which would be about a 9mm shank to allow for the projection, .......................... .all in all a nightmare
    Is it not possible to use a 2 start 22 x 4
    FYI Calculation of Thread Lead Angle | MITSUBISHI MATERIALS CORPORATION
  7. Likes Fullmetaleng, Bobw liked this post
  8. #6
    Nov 2020
    GEORGIA
    5
    manufacturing team tried to make part with self made tool and had exactly those problems since shank was 9 mm it could not take the load and was breaking. We suggested design team to change thread to 2 start 22x4 but they declined saying "since thread like this exists it is possible to make it so its your problem". So in the end its my problem.
  9. #7
    Jan 2007
    Norfolk, UK
    20,912
    16353
    16778
    Tell them to find the tooling!
  10. Likes Milland liked this post
  11. #8
    Jan 2005
    The Netherlands
    6,440
    335
    1835
    Have a special tool made out of a solid piece of carbide perhaps
    How deep would be interesting
    Sinker EDM the TR22x8 is also possible I think
    Peter
  12. #9
    Nov 2020
    GEORGIA
    5
    I will try custom made tool, its a 60mm blind hole
  13. #10
    Jan 2005
    The Netherlands
    6,440
    335
    1835
    Let us know the outcome please
    Peter
  14. Likes Fullmetaleng liked this post
  15. #11
    Mar 2017
    LATVIA
    704
    194
    401
    both pieces high strength steel, "non standard" pitch, blind nut on top of that...
    I'd suggest looking for another place to work if you want to keep your sanity
    22x5 seems to be more or less standard, taps available, not that they'd work for a blind hole, but anyway, and ready made rods and nuts also seem to be available
  16. Likes Limy Sami, Fullmetaleng liked this post
  17. #12
    May 2005
    Republic of Arizonia
    1,748
    540
  18. #13
    Jan 2007
    Norfolk, UK
    20,912
    16353
    16778
    Quote Originally Posted by Fullmetaleng View Post
    YIKES! 60 mm long ''nut'', and blind, you must wrestle alligators for relaxation
    Be sure to tell design just how much the special tool costs, .............and IMHO unless you are very lucky, you are going to break a few tools.
    P.S. Double the price if it's too cheap (not that you heard that from me)
  19. Likes Fullmetaleng liked this post
