Broached mild steel coupling - 1.25 - 19 16/32 inv splines
Results 1 to 12 of 12
    Aug 2014
    Noble, OK
    854
    66
    173
    Default Broached mild steel coupling - 1.25 - 19 16/32 inv splines
    No drawing available.
    1018 mild steel okay, cold rolled round bar, 2.00" OD stock, mill OD finish fine.
    1.50" +/- .015 long, .030-.060 x 45 deg chamfer on OD and ID - chamfer dims not critical, just want a significant broken edge.
    19T 16/32 30 deg PA involute internal spline. Pic attached of the specs I'm looking for. 1.276 major diameter, 1.125 minor diameter.
    Qty 10, shipped to 73068. Please email questions or quotes to jaymfleming at gmail dot com. NO OVERSEAS COMPANIES!
    Added pic of what an old part looked like.
    Thanks!
    Apr 2010
    Wisconsin
    6,062
    4179
    3717
    We Hob, Shape, & WEDM, but no Involute Broaching. If they have to be Broached, have you reached out to Jess about these? ( forum member name - reedeprintice )
  3. Likes reedeprintice liked this post
    Feb 2008
    Paradise , California
    1,813
    264
    506
    10 pieces is a short run -I do not have that cutter. If it was 100 I would quote it. Jess
  5. Likes Ox liked this post
  6. #4
    Aug 2014
    Noble, OK
    854
    66
    173
    Quote Originally Posted by reedeprintice View Post
    No problem, thanks though. I've got a local shop I can ask but just wanted more options.
  7. #5
    Oct 2010
    MO, USA
    298
    145
    95
    I have the ability to broach or shape these. Does it matter? What kind of time frame are you looking for.
  8. #6
    Oct 2005
    15,141
    Quote Originally Posted by Zahnrad Kopf View Post
    Should it really matter what process is used for the same final result ?
    I can see maybe no EDM for the affected material properties (but not in plain 1018)
    why broach only ?
  9. #7
    Oct 2010
    MO, USA
    298
    145
    95
    Flat root or full fillet?
  10. #8
    May 2009
    Wyoming
    3,241
    7836
    5223
    That's the spline used on most splined steering wheel quick-release hubs. Except for ours. I think we still have the 16/32 spline hob but tossed the broach years ago. Call any manufacturer of those hubs, you can find several examples in the aftermarket race car parts catalogs.
  11. #9
    Aug 2014
    Noble, OK
    854
    66
    173
    A couple people asked about shaping, which is fine. I specifically asked for broaching because of the assumed economics. WEDM is also fine, but again, I'm not looking to spend a fortune because someone has a process that will work. No real deadline, but we'll say 4 weeks to put a number to it.
  12. #10
    Aug 2014
    Noble, OK
    854
    66
    173
    Quote Originally Posted by gear cutter View Post
    If they'll both fit the same external spline, either is fine.
  13. #11
    Apr 2018
    UNITED KINGDOM
    2,230
    1018
    Quote Originally Posted by Jay Fleming View Post
    You probably want to specify by an MOW for an involute, not major and minor diameters. It shouldn't touch on either one, so those numbers are not that important.
    If someone has a broach that's cool but in most cases, you'll end up shaping this. Broaches don't grow on trees. Pioneer Broach in California does have a big selection, if you want to give them a call.
  14. #12
    Aug 2014
    Noble, OK
    854
    66
    173
    I am no longer needing these parts.
