HDPE bottle feed/timing screw - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
  1. #21
    Sep 2018
    Ohio
    73
    18
    10
    Just says United States / Ohio now.
    No city listed.
    Think Snow Eh!
    Ox
    Well I guess that's a little better. Lol
    Sent from my SM-G950U using Tapatalk
  2. Likes Ox liked this post
  3. #22
    Sep 2018
    Ohio
    73
    18
    10
    Here is an example of one of our timing screws. The pictures are a little dark. I had to turn the lights off due to the glare. But you get the idea.
  4. #23
    Aug 2002
    West Unity, Ohio
    26,073
    6361
    8529
    Well, from your pic/application, it sure looks like you just need to plunge a mill in the same size as your bottle, and interp A and X as you go.
    POLISHING it after the fact is likely one of the biggest parts of this job.
    Think Snow Eh!
    Ox
  5. #24
    Sep 2018
    Ohio
    73
    18
    10
    Think Snow Eh!
    Ox
    I have been to a plant that makes them. They have them on a mill with a 4th axis rotary and cutting the profile with a ball nose. You can still see tool Mark's a little. It is sorta self polishing after a million or so bottles go through.
    I'm not sure how to get fusion 360 to create the code yet. We really dont have time to mess with it but it's one of the many parts needed for the jobs.
  6. #25
    Aug 2002
    West Unity, Ohio
    26,073
    6361
    8529
    If your spindle was at 12:00 - sure - you would need a ball, but I would think that you could come in from 9:00 with a reg end mill and accomplish the same thing seein's that your bottles are apparently located square with the shaft.
    No point makin' it harder than it needs to be.
    {note - "A" axis is the 4th/rotary designation}
    Think Snow Eh!
    Ox
  7. #26
    Sep 2018
    Ohio
    73
    18
    10
    True. What about for rectangle bottles. They are more of my dilemma
  8. #27
    Aug 2002
    West Unity, Ohio
    26,073
    6361
    8529
    IDK.
    You don't use this same screw for rect bottles doo you?
    I would think that you would just use a reg [sqr cornered] mill at 12:00 for that.
    However - doo to the fact that most mills are cupped at the bottom to reduce surface area (chatter/tearing) that you would need to get an actual "flat bottomed" mill, OR just use a smaller tool and make a few passes at it to get to the required width.
    Or maybe I'm lookin' at it wrong?
    Flat Bottomed?
    Ox
  9. #28
    Sep 2018
    Ohio
    73
    18
    10
    I think you are correct. Looking it that way sounds much easier than the 100k lines of code it would take the way the way I saw it done.
  10. #29
    Aug 2002
    West Unity, Ohio
    26,073
    6361
    8529
    Well, this all depends on how big your round bottles are.
    The screw on the floor looks like it could be kind'a big?
    Is this bigger than say ... 2"?
    Or maybe that is just a counter top and whatever appears to have feet behind it isn't a bench?
    Think Snow Eh!
    Ox
  11. #30
    Sep 2018
    Ohio
    73
    18
    10
    The screw on the floor is 4.5 inches at its biggest. The bottle in this pic is 2 inch OD.
    Also something to look at is that the round bottles are a little more forgiving when they transfer from the conveyor to the screw and easier to seperate and not crash.
    The rectangle will be a little more challenging. These are 2.5 x 1.5 inches
  12. #31
    Aug 2002
    West Unity, Ohio
    26,073
    6361
    8529
    A 2" end mill is getting to be kind'a largish, but that could likely be done with a 2" shouldering face mill too (several passes) and that is much more common.
    The rect is another issue.
    You was asking for a [replacement?] screw being made, but your last statement sounds like you may need a system re-design to accommodate something that it wasn't originally intended to deal with?
    Not simply a screw being made.
    Think Snow Eh!
    Ox
  13. #32
    Oct 2005
    17,284
    Quote Originally Posted by tobydbaker74 View Post
    I think drawing it in inventor is pretty easy, where is the difficulties ?
    Cam side of defining several passes to get the required round shape ?
  14. #33
    Mar 2011
    ohio
    59
    12
    10
    We are looking for someone to machine different size screws as we grow into packaging and bottle handling lines. We prefer someone that has knowledge of making these and not someone that thinks they can. Not to anger anyone but I have been down that road before.
    PM sent
    Charles
  15. #34
    Sep 2018
    Ohio
    73
    18
    10
    Yes. On the cam side. Drawing in inventor is the easy part for us.
  16. Likes digger doug liked this post
  17. #35
    Sep 2018
    Ohio
    73
    18
    10
    Think Snow Eh!
    Ox
    Yes exactly. I have this screw off of a labeler and need to design new screws for different bottles based of of this screw.
  18. #36
    Aug 2002
    West Unity, Ohio
    26,073
    6361
    8529
    Well, making the screw feed the rect shouldn't be an issue.
    How you get them started into the screw is a horse of a different color.
    Think Snow Eh!
    Ox
  19. #37
    May 2020
    Oklahoma
    Please email me [email protected] I need to what sizes we're talking about before I can say we can do it. Thank you.
  20. Likes tobydbaker74 liked this post
  21. #38
    Mar 2017
    New York
    I have made these several times before. I will need to know the size of bottle(height & diameter), length you would like the screws and the size of arbor they are going on. Please email me with your requirements.
    Nick Altizer
    I.T. Manufacturing
    [email protected]
  22. Likes tobydbaker74 liked this post
  23. #39
    Feb 2006
    so cal, usa
    659
    256
    171
    we have had feed screws made by a company called Kinsley, 215-348-7723 and I talked to Brandon. Very good work, they know feed screws well, it's their buisness.
  24. Likes tobydbaker74 liked this post
  25. #40
    Oct 2019
    Montana
    37
    8
    Shop I cut my teeth in made these a few times; they design/build to suit custom manufacturing machine(assembly, sampling etc) it’s all they do... Based in Smithfield, NC, Tarheel Tooling and Precision Machining.
  26. Likes tobydbaker74 liked this post
