Looking to Manufacture Small Parts
Page 1 of 2 12 LastLast
Results 1 to 20 of 23
    Aug 2019
    CANADA
    Ontario
    Default Looking to Manufacture Small Parts
    Hi -
    I'm creating a stainless steel pocket compass (similar to a pocket watch style). I've attached the technical drawings and dimensions are as follows:
    Outer Ring (photo 1) - 69.61mm in Diameter / depth of 8.18 mm
    Back house (photo 2): 67.66 diameter / depth of 2.5mm
    Direction house (photo 3): 60.04 diameter / depth of 3.83mm
    Can you please help me answer the following questions:
    1) Is CNC the best manufacturing process for this?
    2) What is the most cost effective way to manufacture this locally (Canada or US)? I am not interested in outsourcing to china / india.
    3)What should I be looking for in a CNC manufacturer's capabilities? Is there any specialty machinery they would require to complete something of this nature?
    4) We are not machinists, wondering if there is any equipment we can purchase to manufacture this on our own (or is this idea too lofty!)
    Any recommendations on augmenting the design to be more cost effective is also welcome.
    Thank you in advance.
    Cheers
    Melissa
    Apr 2005
    Beaverdam, Virginia
    7,441
    702
    3515
    Quantities mean everything. What volume are you looking at? Then we can direct you on the most economical per piece method of manufacture.
    Aug 2019
    CANADA
    Ontario
    Prototype to begin with, followed by a production run of 50-100 pieces.
    Feb 2011
    BFE Nevada/San Marcos Tx
    1,240
    1112
    671
    So you want ......
    Sep 2007
    Washington
    5,243
    199
    1580
    I see two tricky bits:
    1. The post on the 2.5mm disc -- possibly a pressed-in pin would work OK? Machining this from solid would be costly
    2. The engraving within "Direction House" -- being on a slanted surface, the engraving would need to be done with a tilting rotary table or 5-axis machine, which will eliminate many "standard" machine shops.
    As to CNC, sure, done in batches of 100, CNC would be the way to go.
    Can you do this in-house? Sure, but figure on ~$150,000 investment to get the required type of machine, unless you try to find used machinery in which case it could be anywhere from $10,000 to $100,000. In the best case then, you would be spending at least $100 per part (batch of 100, $10,000 machine investment) just to get the machinery. Then there's programming, tooling, power, air, etc.
    Regards.
    Mike
    Aug 2019
    CANADA
    Ontario
    Quote Originally Posted by dalmatiangirl61 View Post
    So you want to manufacture a product, yet you think so little of machinists that you do not have one on your team? Good luck!
    I'm a person with an idea, i am a one person team right now. thanks for understanding
  7. Likes wheelieking71, Ox liked this post
    Aug 2019
    CANADA
    Ontario
    Quote Originally Posted by Finegrain View Post
    Regards.
    Mike
    Thank you Mike,
    Do you know what I should expect to pay for such design for a prototype and a 100 piece run? (stainless steel for the base and back plate and brass for direction house).
  9. #8
    May 2009
    Canandaigua, NY, USA
    2,888
    141
    1291
    IMO, at 50-100 pieces no normal person will be able to afford this. Machined parts in this country are expensive. You should make up detailed drawings, with tolerances, and do an RFQ here to get some real numbers. Then you'll probably reconsider going off-shore. It's completely impractical to consider setting up to do it yourself until the quantities are much larger.
  10. #9
    Jul 2012
    Washington
    2,933
    1139
    1185
    Prints big enough to read would help. Perhaps do the engraving with a laser since I am sure you need it on an angled surface like that.
  11. #10
    Jan 2013
    Gilbert, AZ
    5,995
    7551
    7636
    What kind of comment is that?!
  12. Likes pianoman8t8, Garwood, morsetaper2, OCMFG liked this post
  13. #11
    Jul 2019
    CANADA
    Alberta
    I have programmed a watch for a customer of mine, we did housing, faceplate and backring. You can see the resualts, beautiful craftmanship.
    All done on a Small vertical mill, and manual lathe with some creatively.
    Novo Watch – NOVO watch
  14. Likes Rob F., Joe Miranda liked this post
  15. #12
    Aug 2012
    California, Central Coast
    3,755
    2195
    1480
    Look at how old pocket watches were made. They were made in the thousands if not more, all well before CNC machines came on the scene.
    Maybe a thin sheet stamping to make the back and it presses or epoxys into the bezel (part with N,S,E,W on it) Maybe the bezel could also be pressed or stamped, personally I would like to see machined a part there though.
    A small (tiny) spinning lathe could do the back also, instead of stamping it.
  16. #13
    May 2016
    Ohio
    22
    Could you send some better drawings to me? I can give you some pricing for both phases. [email protected]
  17. #14
    Jul 2018
    New Jersey
    18
    Melissa,
    To avoid filtering through all the comments thus far (typical in most posts). Please e-mail me at [email protected] m
    I'll discuss some ideas with you and see if we can do anything.
    Regards,
    Jason
  18. #15
    Apr 2007
    Pillager, MN
    5,765
    1876
    5270
    Quote Originally Posted by CROSSHATCH View Post
    Melissa,
    Regards,
    Jason
    Are all 18 posts for poachin' work? Good job.................................
  19. Likes wheelieking71 liked this post
  20. #16
    Apr 2005
    Beaverdam, Virginia
    7,441
    702
    3515
    Quote Originally Posted by david n View Post
    The rules for this section and the machinery and parts for sale section are no longer enforced, plain and simple.
  21. Likes alan speyrer liked this post
  22. #17
    Aug 2002
    West Unity, Ohio
    25,419
    5677
    8094
    Quote Originally Posted by Dualkit View Post
    You apparently have not read the rules lately.
    You need to have 50 posts to post a "My Shoppe Needs Work" ad.
    There is nothing stated by the Powers That Be (The Don) that those with few posts cannot bid on work.
    Even if there was, we wouldn't know it if they just placed their bid via e-mail or PM.
    You don't even need to be a member here to view these posts.
    How would you enforce anything?
    If you wunna bitch about the rules not being enforced, maybe you need to brush up on the rules?
    Now, on the other hand - doo I agree with you?
    Sure.
    But that's not the hand that I was dealt, nor the ability to enforce it if it were the case.
    [edit]
    Even without a bunch of posts about his concern for Yankee Health Care on this site, he very well may be a frequent browser.
    And on a site that is paid for by advertisers that are looking more at "number of hits" than bullshit posts, this guy may actually be a "contributing member" in other ways.
    [/edit]
    Think Snow Eh!
    Ox
  23. Likes wheelieking71 liked this post
  24. #18
    Nov 2014
    Florida
    3,949
    1590
    1841
    ??? Don't follow this logic (#2)
    Regards.
    Mike
    The engraving could be done on a little fixture that would present the tapered/slanted face normal. It would have to be "played" with a bit to get it to look nice enough however. You would see some variance (guessing not much with a small enough ball endmill) as the curvature changes, but if it was me I would project the characters onto the surface, than 3d them. Fixturing would not be ideal as you would need to rotate the part/fixture 4 times for each piece, but doable for a small prototype run.
  25. #19
    Apr 2005
    Beaverdam, Virginia
    7,441
    702
    3515
    Sure.
    [edit]
    [/edit]
    Think Snow Eh!
    Ox
    My disdain was mostly directed at the for sale section where people sign up to use this as free E-bay. Some have been warned then turn around and keep listing items. They aren't offering bargains either, usually listing at E-bay asking prices. Due to the abuse contributing members selling something quickly end up bumped down.
  26. Likes Ox, wheelieking71, Philabuster liked this post
  27. #20
    Aug 2002
    West Unity, Ohio
    25,419
    5677
    8094
    Kan't say that I heave looked at those boards much in the last several years.
    Also - I'm not sure the rules there.
    Also - if you noted the other day that I mentioned on one of Beck's posts on the CNC board that I would delete him if I could, but he wasn't within my reach.
    Think Snow Eh!
    Ox
