Looking to Manufacture Small Parts - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
  1. #21
    Aug 2010
    Medina OH
    1,716
    107
    714
    The engraving could be done on a little fixture that would present the tapered/slanted face normal. It would have to be "played" with a bit to get it to look nice enough however. You would see some variance (guessing not much with a small enough ball endmill) as the curvature changes, but if it was me I would project the characters onto the surface, than 3d them. Fixturing would not be ideal as you would need to rotate the part/fixture 4 times for each piece, but doable for a small prototype run.
    I got this neat machine that was made with alien technology in the 1930's for just such work...
  2. #22
    Dec 2014
    CANADA
    British Columbia
    1,275
    361
    581
    Quote Originally Posted by Finegrain View Post
    I see two tricky bits:
    2. The engraving within "Direction House" -- being on a slanted surface, the engraving would need to be done with a tilting rotary table or 5-axis machine, which will eliminate many "standard" machine shops.
    If the font could be simplified there should be no issue doing engraving like that on a angled surface. Agreed though if the font has to be a serif one tilting or otherwise fixturing normal to that face would help.
  3. #23
    Mar 2017
    LATVIA
    301
    76
    163
    I'd suggest looking at laser engraving the markings, should be a lot more economical than mechanical engraving, and doable with a laser that has 4th axis, maybe even with 3axis, if there is no problem with laser reflecting from the angled surface, then the drawing could be stretched so the letters come out straight
