Looking for a supplier Hardened High-Speed M2 Tool Steel Sheets
I love McM, but I wish their catalog was better at fact-checking their listed properties and such. If that sheet is indeed RC65, there's no way the yield strength is only 65Ksi.
Dead soft I could believe that yield, but not at RC65!
FWIW, if that is hardened and has good flatness specs, I don't think that price is too bad. If you get unhardened sheet and (in low quantities) got it HT'd, you'd likely have some warpage or other headaches to deal with.
when i was in the game all our sheet was soft in various grades, that is how it came in.
cut small sheets 400 x 200 mm then HT as a sheet and ground as a sheet, cut things out of those in some instances in the hard state for quick turnaround items
Mostly cut out of soft sheet then rough grind, send out to HT then finish grind. a bit longer turn around on these.
Have not seen anything in 1mm we only went down to 2mm thick.
Sorry don't have a supplier contact for you.
