Milled Steel Part, approx 5 lbs
Results 1 to 6 of 6
    Oct 2019
    Michigan
    8
    Default Milled Steel Part, approx 5 lbs
    Hi Everyone,
    I'm looking for a machining source that can deliver a small quantity of mild steel parts. The part is prismatic in nature, but oriented on different planes. By my assessment, the part would be a candidate for a 5-axis machining center, or a 4-axis center with a couple of setups. I am however not a machining expert. The part does not require heat treatment.
    In-Process 3D data and 2D dimensioned drawings are available.
    Quantity: 4pcs initially. This part is expected to have multiple part numbers with slightly different geometry, meaning that two feature groups will be in a different location in increments of around .050" of an inch. All variants could be made from a common partially machined part. Total volume of all variants conservatively 128 pcs/yr.
    Rough Dimensions: approx. 19.5" long, 2.75" wide, and 2" high. Finished weight approx. 5 lbs.:
    Material Required Date: 3/02/2020
    Discussions will follow agreement on terms of non-disclosure.
    Terms of Payment: 2% 10/Net 30
    Message me privately on this forum if you are interested.
    Jun 2019
    South Dakota
    51
    14
    13
    just a thought on the lack of interest on this post, I don't thing too many shops are going to be interested in doing a job and hoping for payment. Since you are a new member there is a certain amount of distrust inherently given to you due to other new members non payments in the past. if you truly need this made by a reputable shop and in a speedy manner to good tolerances and specs you should have no problem with prompt payment in full. I've been in business with my dad for nearly 25 years, and we would never agree to such terms unless it was a customer we had much previous dealings with and trusted fully. I hope you can make a deal with one of the members here for the benefit of both parties. there are a lot of very good machinists in here, please respect them and their needs as well. good luck.
    Oct 2019
    Michigan
    8
    Thanks for your advice. While I'm new to this forum, I'm not new to the business of engineering and machining. Of course, everything is negotiable, including terms of payment. From my perspective, I think 2% 10/ Net 30 are reasonable terms and are not outside the norm of business today. I'm open to counterproposals however.
    Nov 2013
    north of Bean town
    438
    71
    138
    id be open to cash if local or credit card...then maybe if you come back we could discuss terms.
    Aug 2012
    California, Central Coast
    3,519
    2187
    1363
    Quote Originally Posted by NautiSouth View Post
    Curious about what is wrong with the shops you normally would use?
    Jun 2016
    Oregon
    17
    I would like to look at your drawings and see if I can come up with a quote for you. Please send cad files .igs works well if you have notes or .dxf works well too if there are no notes in the drawings.
    I do not share customers drawings or ideas and I am more then willing to sign a Non-Disclosure Agreement if required.
    I normally require 50% down and remainder due at delivery or net 30 I am very negotiable for the Terms of Payment: 2% 10/Net 30 but may need down.
    Vincent Eggleton
