NautiSouth
- Oct 21, 2019
Hi Everyone,
I'm looking for a machining source that can deliver a small quantity of mild steel parts. The part is prismatic in nature, but oriented on different planes. By my assessment, the part would be a candidate for a 5-axis machining center, or a 4-axis center with a couple of setups. I am however not a machining expert. The part does not require heat treatment.
In-Process 3D data and 2D dimensioned drawings are available.
Quantity: 4pcs initially. This part is expected to have multiple part numbers with slightly different geometry, meaning that two feature groups will be in a different location in increments of around .050" of an inch. All variants could be made from a common partially machined part. Total volume of all variants conservatively 128 pcs/yr.
Rough Dimensions: approx. 19.5" long, 2.75" wide, and 2" high. Finished weight approx. 5 lbs.:
Material Required Date: 3/02/2020
Discussions will follow agreement on terms of non-disclosure.
Terms of Payment: 2% 10/Net 30
Message me privately on this forum if you are interested.
