Steel 2.5-4 acme nut, 3.375" OD, 0.75" long
2x clean up and put holes in 2x2x12.5" aluminum bar (1 as shown, 1 mirrored)
2x aluminum spacer, 2.5" OD, .5" ID, .5" thick
Nylatron NSM acme nut, 3.375" OD, 3" long, fine thread on OD
steel flange with counterbores, 5" OD, 1.6" thick, thread milled hole in center to fasten acme nut
Triangular steel block 7.75x7.75x5.67"thick with tapped holes.
Tolerances are pretty much all +-.005". Qty 1 unless otherwise noted.
I will e-mail prints to whoever needs them. Please quote including shipping to 04011. I would like a 4 week turnaround.
You don't necessarily have to bid on all of them. The little stuff is easy to fit in a flat rate box. The triangular block, on the other hand, is heavy. I plan to give the flange and nylon nut to the same shop since they are mating parts and must fit together.
