Need Grinding Wheel Arbor Washers
Likes Likes:  0
Results 1 to 5 of 5
    Feb 2007
    Needham, MA
    385
    23
    13
    Default Need Grinding Wheel Arbor Washers
    I need to find some raised center washers, for grinding wheel arbors. They are steel, 3"D x .110" Th.+- x .500" H. The center area is raised for about 1.150"D.
    Payson.
    Oct 2005
    13,632
    Sopko doesn't have any ?
    Feb 2007
    Needham, MA
    385
    23
    13
    Thanks Digger.
    These are used on special bench lathes, in the production of musical instruments. What we have a stamped. I'm hoping to pay under $10. Sopkos must be a lot more than that.
    Payson.
    May 2017
    Massachusetts
    217
    140
    96
    I usually just turn these to suit on a lathe. Easy enough.
    Jun 2012
    Michigan
    9,466
    3229
    3394
    Any chance these might do?
    HA6100SP - Baldor - Renewal Part | Galco Industrial Electronics
    yes the OD need trimming.
    or these 2" x .500
    https://www.amazon.com/Grinder-Washe.../dp/B019JPL3WK
    if not having any 3" round stock....One can ream or drill a .500 or 1/2 hole hole in a piece of flat stock, rough/hack it near round, then chuck it on a stub, out of a chuck and turn the diameter and face on a lathe..
    or: Make hole and turn diameter with hack flat stick to near 3" round , then finish on a stub post with a bench grinder. Yes scribe the 3" OD circle off your punch mark for rough-in.
