Need quote
Likes Likes:  0
Results 1 to 5 of 5
Thread: Need quote
    Jan 2002
    Oklahoma, USA
    693
    392
    53
    Post
    Needing a quote for some small parts. Material is 1045 polished and ground, .500 diameter. Rods are 3.870 length with a 1/4-20 hole about 3/4 deep in each end. will need 200.
    Paul
    Actual length needed is 3.873/3.878
    [ 07-29-2006, 11:01 AM: Message edited by: PHDesigns ]
    Feb 2005
    blackstone, ma
    120
    Post
    What's the tolerance on the o.D. and what surface finish are you looking for.What is your time frame and what state are you located in and the bottom line, what are you looking to spend? We would be glade to offer our services on this item.Chuck Hanson contact pioneer [email protected] phone(508)883-1588
    Feb 2005
    blackstone, ma
    120
    Post
    Jan 2002
    Oklahoma, USA
    693
    392
    53
    Post
    I am in Oklahoma City, Oklahoma. I buy the 1/2" 1045 TPG (or I just say polished and ground when I order) and use as is. It has a polished finish and is .500 diameter. Only work should be to drill and tap each end and cut to length. Need in 30 days.
    Feb 2005
    blackstone, ma
    120
    Post
    If you supply the material (shared risk)we would machine the parts per your spec. for $2.50 each.If interested contact Chuck Hanson (508)883-1588 or [email protected]
