Need quote for hand/way scraping
Likes Likes:  0
Results 1 to 4 of 4
    May 2020
    Florida
    25
    Default Need quote for hand/way scraping
    I have four parts, each part is no more than 4x4"
    How much to hand scrape the bottom of these?
    Thank you
    Dec 2016
    Wisconsin
    100
    19
    Picture or drawing?
    More info is needed
    Jul 2007
    Florida
    792
    94
    401
    Depends on what you want.
    Do you just want decorative scrapping, or do you need 40 points per inch bearing?
    What are the shapes like? Square/rectangular is easier/cheaper than convoluted shape.
    More details needed.
    CarlBoyd
    Jun 2012
    Michigan
    11,300
    3870
    3990
    That small likely you could grind them to .0002 or so and have very little to scrape.
    Most grinder hands can fudge up a set-up for some odd part and get .0002 on a 4x4" part.
    likely a surface grinder job...perhaps a half hour each..If having a near common set-up
    .. set in/on a compound vise or atop a tilt angle plate of an odd holding position...with such jig on a magnetic chuck..
    then add decorative scrapping and a true up to rid the last .0001 or so if needed close....
    photo of the parts would be helpful
