need stainless steel bracket bent 35 pcs
Likes Likes:  0
Results 1 to 1 of 1
    Mar 2007
    warren, mi
    1,184
    125
    306
    Default need stainless steel bracket bent 35 pcs
    please send request for prints to [email protected] we are looking for a company to bend a stainless steel bracket about .75 wide about 2.5" long with a through hole on one leg and a drilled and tapped hole on the other. tapped hole is 8mmx1.25 and drill hole is 10mm if I remember correctly. bracket material should be 6mm thick. .25" thick is acceptable, and bracket must be cosmetically free of gouges or defects on the surface.
    please send email to the above address and I will forward you the print.
    thanks for looking
    Jerry
