Overnight Engineering - Atlanta, GA, USA
Likes Likes:  0
Results 1 to 1 of 1
    Dec 2003
    suburbs of Ann Arbor, MI, USA
    13,165
    451
    1085
    Post
    Small all-manual machine job shop in metro Atlanta, GA. I'm the only one here so I have full control and responsibility for all shop work.
    Specializing in prototype work and small batch production 1-25pcs. I'll consider any job that the machines can do within their range of capability. Fast turnaround, emergency breakdown service, pickup and delivery service. Custom gears up to 16DP and 6" OD. Mig, Tig and Stick welding. Full range of service from engineering consultation to design & build including the "nuts and bolts" of machine building, process automation, jigs & fixtures, conveyance and material handling, motor controls, machine guarding, automatic lubrication systems, assistance with design suggestions, tolerancing, and of course, building! In-plant installation and start-up services as required.
    UPS shipping at actual cost to customers outside the metro area.
    Machinery includes:
    Bridgeport Mill 2J - 9x42
    Adcock & Shipley 1ES horizontal mill
    Clausing C250A automatic horizontal bandsaw
    Powermatic #87 vertical bandsaw
    Monarch 10EE 10x20 lathe
    Clausing Colchester 13x40 lathe
    Clausing 5914 lathe 12x36
    Clausing 20" drill press
    Barber-Colman #6-10 gear hobbing machine
    Dake #1-1/2, #3, & #4 arbor presses
    Diacro #4 rod, tube & bar bender
    Tennsmith 16ga x 36" shear
    Tennsmith 16ga x 48" box & pan brake
    Diacro benchtop press-brake
    Miller 251 Mig welder
    Miller Econotig welder
    Matt Isserstedt, owner
    ph 770-656-0161
    mattofvinings AT aol DOT com
    I always like friendly visits...by arrangement.
    [ 01-30-2006, 08:11 PM: Message edited by: matt_isserstedt ]
