RFQ 1/4" dowell pins 316L
Results 1 to 16 of 16
    May 2004
    Ridgefield, Wa USA
    495
    163
    61
    Default RFQ 1/4" dowell pins 316L
    I am looking for someone to supply me with 1/4" dia x 1.25" long 316L SS dwell pins they are not a precision part but I would like them to be within .001" in diam and .010" in length they need a small chamfer on each end. Quantity 400 on the first order I will need them 400 at a time 4 to 5 times a year. Shoot me an email and we can discuss it further.
    I am in WA State close to Portland, OR I would prefer someone close by and no overseas quotes please.
    [email protected]
    Apr 2015
    Connecticut
    429
    245
    180
    This seems like it would be an off the shelf kind of item since McMaster Carr stocks them I would look for a local fastener company
    May 2004
    Ridgefield, Wa USA
    495
    163
    61
    McMaster Carr is pretty high and they don't need to be precision ground they won't be used for locating in precision holes. I was hoping someone with a lathe or screw machine could make them fairly cheap if not I will source them from McMaster Carr. Bolt stock or just standard 316L rod would work. The part is used as a tension mechanism in the side of a dovetail slot.
    Oct 2005
    13,066
    Quote Originally Posted by gundog View Post
    Got a "Target Price" ?
    May 2004
    Ridgefield, Wa USA
    495
    163
    61
    Precision ground pins are about $1.83 ea for 316 and about half that for 18-8 from McMaster Carr I would expect much less than that.
  6. Likes digger doug liked this post
    Jan 2013
    Plainfield, Indiana, USA
    1,670
    1237
    890
    US minimum wage will prevent US mfg of this pin. Suggest you look overseas if you have to have parts for less than $1.00 each
    Apr 2005
    Beaverdam, Virginia
    6,539
    389
    2818
    So if a person bought cold finish 1/4 stock spec'd at +/-.001, mill finish on the O.D. would be ok, without turning?
  9. #8
    May 2012
    Pittsford, NY
    934
    672
    599
    McMaster Carr is making a profit on a part supplied to them at a sales price of $1.83. A markup of 50% is not unusual in many supply chains. You need to find out who is supplying McMaster Carr. Not sure how you'd do that...
  10. #9
    Apr 2005
    Beaverdam, Virginia
    6,539
    389
    2818
    Quote Originally Posted by wheels17 View Post
    McMaster isn't buying 400 at a time.
  11. Likes digger doug, HiNi, BugRobotics liked this post
  12. #10
    Oct 2005
    13,066
    Quote Originally Posted by Dualkit View Post
    Suggest the OP pulls in the orders for a full year (1600-2000) to get to
    the desired price.
  13. #11
    May 2004
    Ridgefield, Wa USA
    495
    163
    61
    If the price is not right I will make them using the following method. I make another pin this way. I buy the rod stock 316L bundle them 10 at a time put hose clamps around the bundle cut to length with a manual band saw 10 parts at a time, chuck each one in a drill and smooth the ends adding a slight chamfer. I don't want to make hundreds this way but at $1.83 it makes sense to do so. These are not super precision parts and they will be inside an assembly that can't be seen in the finished part. I would share a drawing of how the part is used but I will be filing for a patent on it so without a non disclosure signed I won't share any drawings. The parts is dirt simple at least this part of it. The pin will need to fit inside a slot cut by a 1/4" EM and it doesn't have to be a close tolerance fit.
    I appreciate the advice but I am looking for quotes if it doesn't make money for you to make them that is OK I don't have a CNC lathe or screw machine but maybe someone out there does that doesn't have enough work for it that could make these for a price that makes sense for me not to use the method above.
    Mike
  14. #12
    May 2004
    Ridgefield, Wa USA
    495
    163
    61
    Thank you to those who replied I have a local company that will make them and have them for me in a week. .80 each. That makes more sense than my manual approach. I may have a flange part that I will shop out soon. Is this an acceptable way to get quotes? The next part I will provide a drawing.
  15. #13
    Apr 2005
    Beaverdam, Virginia
    6,539
    389
    2818
    Thanks for the quick update, as usual these days I just miss.
  16. #14
    Feb 2009
    920
    127
    153
    Well if you want to pay 5cents more on each one, be my guest. shipping via USPS small flat rate box was only $7.90.
  17. #15
    Oct 2014
    Maine
    724
    47
    347
    For stuff like this I would check out Pivot Pins (I've used their products in the past) and Wilson Mfg. (which I haven't, but am about to). They do a bunch of standard, non-ground pin-like objects in various materials and may have what you need inexpensively and off the shelf.
  18. #16
    May 2004
    Ridgefield, Wa USA
    495
    163
    61
    Quote Originally Posted by alan speyrer View Post
    It wasn't the shipping it is because they are local and they deliver free this is going to be something I buy over and over so having it local is the upside.
