RFQ: 2 easy cnc lathe jobs, 60 pcs each.
Likes Likes:  0
Results 1 to 5 of 5
    May 2020
    Ohio
    16
    Default RFQ: 2 easy cnc lathe jobs, 60 pcs each.
    The site will not allow me to add attachments from my phone. I have added drop box links to a basic pdf view of each piece for general reference.
    Dropbox - FMW125.pdf - Simplify your life
    Dropbox - FMW225.pdf - Simplify your life
    FMW125 (this is a section view):
    -Overall length is roughly 2.25"
    -Tolerance is +/- 0.003" other than the drilled hole depth which is +/- 0.01"
    -Material is free machining steel.
    -Quantity is 60 pcs.
    FMW225:
    - Diameter is 1.375" length is 0.75"
    - Center hole is reamed
    - Other than center hole, tolerance is +/- 0.003"
    - Material is 1-3/8" x .312" wall DOM tube or CRS depending on cost of drilling vs DOM tube.
    - Quantity 60 pcs.
    If you are interested in quoting this work, please contact me freedommachine at protonmail DOT com. I have solidworks files for these parts but can convert to your preferred file type upon request.
    Thank you,
    -John
    Oct 2005
    17,712
    Just use the snipping tool to take a screenshot of the print/model/whatever.
    You can then post that here.
    May 2020
    Ohio
    16
    The site won't allow me to post any attachments here from a mobile device. I get a message saying something like; "This option not available on mobile version."
    Are the drop box links not working?
    After reading the rules sticky - probably should've done that first, I'd rather use a 3rd party host than a direct attachment anyway.
    This way I'll have the ability to remove any visual representation of my product from the internet after the job has been awarded.
    The links go directly to a drop box account for my company. Clicking on them allows you to view the pdf. It will not start a direct download.
    Mar 2019
    Massachusetts
    246
    129
    127
    I sent you an email.
    Apr 2005
    Beaverdam, Virginia
    8,289
    964
    4046
    Quote Originally Posted by DanASM View Post
    Did you get a CNC? I would think you would not want to run 60 piece jobs on a cam automatic.
