Results 1 to 11 of 11
10-03-2019, 11:54 PM #1
RFQ - (2) Machined Aluminum Parts
Looking for a pair of the attached parts. 6061 aluminum, designed to be machined as a single part up until the .375" counterbore, then slit into 2 pieces and finished. Can supply models in addition to print (also higher res print, could only post this due to forum limitations). Could be a manual or CNC part.
10-04-2019, 08:25 AM #2
Could those internal 0.125" radii be increased? Also, what are the surface finish requirements? Can this be made from 2" wide stock and the outer edges of the clamp left raw extrusion? Is the threaded hole depth a minimum call (do you care if it is deeper as long as it doesn't break through)?
10-04-2019, 10:13 AM #3
PM sent. Thanks for the opportunity.
10-04-2019, 10:48 AM #4
The .125" internal radii I put in so it could possibly be made manually. For a CNC operation those could even go up to .290" if you wanted to profile the whole thing with a 1/2' end mill. For the 1/4"-20 threaded holes I would like as much thread as possible in the bottom piece without punching out. The upper part should actually be a .257" clearance hole down to the slit. Nothing is critical except the .875" hole because it has to grip a .875" piece of tube, so I would say that oughta be +/-.002".
Rick Finsta liked this post
10-04-2019, 02:59 PM #5
mailbox is full
10-04-2019, 03:22 PM #6
10-04-2019, 11:23 PM #7
Can you send 3D model to [email protected]? Thanks.
Sent from my SM-N975U1 using Tapatalk
10-04-2019, 11:34 PM #8
10-05-2019, 12:20 AM #9
The 27.9° angle clearly visible in the top right hand (side view) drawing.
Would be easy enough to slitter saw the two in two, or make individually. I assume he would not be happy with a band saw cut. He probably ought let that be known though...
10-05-2019, 01:00 AM #10
Do you guys actually expect to make a reasonable shop rate on work like this?
I'm not trying to be mean or anything,
but it seems that quoting,resolving questions about missing dimensions and billing and shipping will take longer than
making the part.
10-07-2019, 08:13 AM #11
Thank you to everyone who responded to this. I have accepted a quote on these.
