RFQ - (2) Machined Aluminum Parts
Results 1 to 11 of 11
    Jul 2009
    Ijamsville, MD
    475
    18
    19
    Default RFQ - (2) Machined Aluminum Parts
    Looking for a pair of the attached parts. 6061 aluminum, designed to be machined as a single part up until the .375" counterbore, then slit into 2 pieces and finished. Can supply models in addition to print (also higher res print, could only post this due to forum limitations). Could be a manual or CNC part.
    Sep 2017
    Wisconsin
    631
    87
    305
    Could those internal 0.125" radii be increased? Also, what are the surface finish requirements? Can this be made from 2" wide stock and the outer edges of the clamp left raw extrusion? Is the threaded hole depth a minimum call (do you care if it is deeper as long as it doesn't break through)?
    Mar 2018
    Minnesota
    5
    PM sent. Thanks for the opportunity.
    Jul 2009
    Ijamsville, MD
    475
    18
    19
    Quote Originally Posted by Rick Finsta View Post
    The .125" internal radii I put in so it could possibly be made manually. For a CNC operation those could even go up to .290" if you wanted to profile the whole thing with a 1/2' end mill. For the 1/4"-20 threaded holes I would like as much thread as possible in the bottom piece without punching out. The upper part should actually be a .257" clearance hole down to the slit. Nothing is critical except the .875" hole because it has to grip a .875" piece of tube, so I would say that oughta be +/-.002".
  5. Likes Rick Finsta liked this post
    Apr 2010
    westport,ma
    189
    108
    6
    mailbox is full
    Jun 2015
    425
    87
    104
    Quote Originally Posted by JLeather View Post
    I think it would be easier to just make two parts. The 27.9 degree angle feature is the main reason. If you're trying to clamp something having threads on both sides of the slit will mean nothing gets clamped. You'd want clearance on the top part.
    Mar 2019
    Utah
    14
    Can you send 3D model to [email protected]? Thanks.
    Sent from my SM-N975U1 using Tapatalk
  9. #8
    Mar 2014
    Nebraska
    366
    42
    228
    Quote Originally Posted by CosmosK View Post
    I agree with the observation of the threads on both sides of the slit, but depending upon the fit of the threads I would bet it would still clamp. Not sure what 27.9 degree feature you are looking at though.
  10. #9
    Dec 2014
    Arizona
    369
    39
    62
    The 27.9° angle clearly visible in the top right hand (side view) drawing.
    Would be easy enough to slitter saw the two in two, or make individually. I assume he would not be happy with a band saw cut. He probably ought let that be known though...
  11. #10
    Nov 2013
    SoCal
    9
    Do you guys actually expect to make a reasonable shop rate on work like this?
    I'm not trying to be mean or anything,
    but it seems that quoting,resolving questions about missing dimensions and billing and shipping will take longer than
    making the part.
  12. #11
    Jul 2009
    Ijamsville, MD
    475
    18
    19
    Thank you to everyone who responded to this. I have accepted a quote on these.
