Rfq
Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: Rfq
    Apr 2019
    8
    Default Rfq
    First time posting.
    Actually have several items but since this is my first attempt.
    Can be made of a strong aluminum grade or mild steel and the bottom of unit will be threaded for bolt insert and two holes for spanner wrench.
    Stem can be the current M6 x .50 or can be a 1.0 thread thread.
    Thank you,
    George
    P.S. Learning FreeCad currently in attempt to become more efficient and hopefully accurate. Any advice welcome.
    Aug 2014
    California, USA
    41
    6
    32
    Need dimensions and tolerances.
    Sep 2007
    Washington
    5,055
    160
    1417
    How many?
    Regards.
    Mike
    Jan 2007
    Flushing/Flint, Michigan
    7,113
    341
    6018
    Why does the bottom end look so rough?
    Almost like plated abrasive.
    Bob
  5. Likes michiganbuck liked this post
    Jun 2012
    Michigan
    9,289
    3159
    3341
    Some might like centers on such a part if diameters need be concentric or just to aid making..
    "centers optional"l might be added to design..if OK to have centers.
    Yes a cut off part so centers not that important.
    dimensions, tolerances and quantities.
    No i don't want the job.
    Apr 2005
    Beaverdam, Virginia
    6,740
    465
    3016
    Bob
    Looks like chatter in the threads or tearing to me, but I am using a temporary small monitor.
    Apr 2019
    8
    Quote Originally Posted by nihilistic View Post
    I will draw up dimensions tonight and post.
    Need 50 units
    It is rough because I am an amateur and it spun in lathe while turning the base of the stem to my spec.
    Tolerances I am not sure of but if you can give me an indication of the norm I can measure and confirm what would work.
    Thank you for your responses
  9. #8
    Jun 2012
    Michigan
    9,289
    3159
    3341
    If the projection has to enter something off the large thread , then you have to think how close do the diameters have to run together... and the size one or some diameters have to enter. the inside corners.
    Perhaps tell a little of how it might be used.
    QT: [will be threaded for bolt insert and two holes for spanner wrench
    on the other end?
  10. #9
    Apr 2005
    Beaverdam, Virginia
    6,740
    465
    3016
    Even a rough sketch is better than a fuzzy picture sitting next to a metric ruler with verbal descriptions. Also are those diameters concentric to each other? It is hard to tell.
  11. #10
    Dec 2015
    Illinois
    310
    90
    166
    +/-.005" (plus or minus) or +/-.12mm for most dimensions would probably be considered "normal" on a part that size but is obviously dependent on the design requirements. Some designers might spec a +/-.002" or a +/-.010" general tolerance depending on what the part does.
    Also remember that you can, for example, specify a one diameter at +/-.001, another diameter at +/-.010 and the length of a feature at +/-.030. Not everything needs to be governed by a general tolerance.
    A good rule of thumb is if you add a zero to the front of the tolerance you add a zero to the end of price.
  12. Likes S101 liked this post
  13. #11
    Jun 2012
    Michigan
    9,289
    3159
    3341
    The fits are important if one diameter has to go into a hole. and also how concentric the diameter are onto the other.
  14. #12
    Sep 2007
    Washington
    5,055
    160
    1417
    Shirley someone making 50 of these is going to barfeed with a CNC lathe, so it would be pretty challenging to have the diameters not be concentric.
    Thread specs are important though. Everyone knows what M6 needs to be, but the big thread -- is that a standard thread I would find in Machinery's Handbook, or some special?
    Regards.
    Mike
  15. #13
    Apr 2019
    8
  16. #14
    Jan 2016
    New Jersey
    71
    43
    34
    Looks like you're still missing a couple diameters.
    Honestly if you're an amateur at least go download a copy of Fusion 360 and learn how to make a fully defined drawing, there are surely some Youtube videos that will guide you on it. It'll be invaluable to you as a machinist or designer. It'll also significantly decrease the amount of time you waste looking for quotes.
    If you have a 3D model of this part I suggest you go take a look at the online quoting companies (Xometry, Protolabs, etc.), it will at least allow you to put off learning how to make engineering drawings for the time being.
  17. Likes S101 liked this post
  18. #15
    Jun 2012
    Michigan
    9,289
    3159
    3341
    Quote Originally Posted by S101 View Post
    You are/seem to be way ahead of yourself..and so needing help that perhaps a book might help you greatly.
    Here are a few such books..The local library will also have good book... such may also help avoid design errors.
    https://www.amazon.com/s?k=blueprint...l_8p0b9i0ang_e
    If this is a true part then you might tell what and where it may be used so the guy here might help avoid design errors.
    I think a hand held book beats study on the inter-net because a writer will take step by step form a beginning...
  19. Likes S101 liked this post
  20. #16
    Apr 2019
    8
    This part goes on the bottom of a damping tube in a set of motorcycle forks. The stem holds a piston with shims clamped top and bottom to dampen the flow of the fork fluid.
    Here is same concept different fork
    I will complete the measurements as I have time today.
    I am not a machinist I tune suspension for off road motorcycle racers and that translates to the general public's motorcycles.
    I will look into your suggestions as mentioned before I will need to know how to go forward with other items I am in need of.
  21. #17
    Jun 2012
    Michigan
    9,289
    3159
    3341
    My BSA had damping forks but I never had them apart.
    Good we have some bikers here so likely they can help the design and the print.
    damping tube of motorcycle forks - Google Search
  22. #18
    Apr 2019
    8
    Here is the other measurements I believe you were referring to and a correction on stem thread pitch.img_0723.jpg
  23. #19
    Jun 2012
    Michigan
    9,289
    3159
    3341
    likely still short ..think the spanner circle dia is still missing but would have to see all dimensions to tell.
    And perhaps +- limits if any sizes are critical to fit some place..agree a fit to just go into a spring would likely not be critical
  24. #20
    Feb 2009
    938
    146
    159
    I wouldn’t bid on this part unless I had the part to be reproduced in my hands to make my own drawing based on measurements I made.
    QUOTE=michiganbuck;3342457]likely still short ..think the spanner circle dia is still missing but would have to see all dimensions to tell.
    And perhaps +- limits if any sizes are critical to fit some place..agree a fit to just go into a spring would likely not be critical[/QUOTE]
