RFQ 420 stainless turning and milling
Is the part highlighted in blue actually tapered almost imperceptibly or is this just an artifact of the modeling?
What kind of surface finish do you need?
Hi, Thanks,No, the part does not taper in that area should be straight 8mm diameter. Not sure exactly how to answer the finish question. Does not need to be high polish. Can be just the machined finish as long as it's pretty smooth. The one I have in hand appears to have been vapor honed or fine bead blasted. That would be fine also.
