RFQ 420 stainless turning and milling
Likes Likes:  0
Results 1 to 7 of 7
    Jun 2019
    Arizona
    Default RFQ 420 stainless turning and milling
    Hi, I'm needing a quote to make 50 of these in 420 stainless steel. STP file. Let me know if you need a different formatschaafcollet no threads 2.4mm.zip
    Thanks.
    Aug 2013
    IL USA
    35
    Is the part highlighted in blue actually tapered almost imperceptibly or is this just an artifact of the modeling?
    What kind of surface finish do you need?
    Jun 2019
    Arizona
    Hi, Thanks,No, the part does not taper in that area should be straight 8mm diameter. Not sure exactly how to answer the finish question. Does not need to be high polish. Can be just the machined finish as long as it's pretty smooth. The one I have in hand appears to have been vapor honed or fine bead blasted. That would be fine also.
    Aug 2013
    IL USA
    35
    Media tumbled perhaps? I can certainly do that.
    Jun 2019
    Arizona
    Sure, that would be fine.
    Aug 2013
    IL USA
    35
    PM sent, just making sure you got it (it's not in my sent messages inbox for some reason).
    Mar 2019
    Utah
    12
    Qoute Sent...pls check your inbox.
