GDO
- Jan 2, 2013
- United States
I have had these produced by supplying my previous shop with McMaster-Carr's tight tolerance ground 440c rod (part number 9094K14). That OD tolerance and finish has worked perfectly across 5 years so I'd prefer to continue with that quality or functionally similar.
OD 0.250 -0.0005, +0
ID tolerance 0.1875 +0.002, -0
length 0.130 +/- 0.001
Please quote for 1000, 2000, 5000.
A minimal edge break is preferred
OD must be free of burrs and deformation as it will be slip fit into a bearing pocket in the final assembly. Parts can be supplied hard or annealed, but the state should be indicated on delivery. Work must be done in the USA
Thank you
Thank you
