RFQ: 70 pieces in 1/8 plexi
elgoldmann
Jun 12, 2020
Culver (Bend) Oregon USA
Qty 70 in 1/8 plexiglass, square must be square and onsize to 0.002", big hole in middle can be off the reservation....I figured make big hole first then capture clamp, do perimeter. Leave film on OK, or off OK too. Some scuffing OK, this will be a tray and get marred over time as used.
I'm running out of hours doing other stuff to make parts!
Check in mail day after receipt (of passable parts!), or propose other terms.
Ed Goldmann
Gulch Consulting
Culver, OR
pdf and stp
M3 Stack Bottom.STEP - Google Drive
M3 Stack Bottom.PDF - Google Drive
I didn't go through all the math, but I'm thinking on a 6" long part, lexan will change more than .002" over a 10 degree F change in temp.
btm
looks like 6.22047 on size to .002" (158.75 stated)
.70 hole abiut center, (79 from side stated.)
"On size" stated but does not mention +-..just on size
does state:
"Square and Onsize Way More Critical than
center hole location and diameter tol"
3.2
1/8" Lexan
Hello,
My name is Jeremy Morecraft with Titan Tool and Machine in Paris Illinois. We could do 70 of plexi parts for $25 each for a total of $1750. A delivery of 1 week. Our email is [email protected] if you're interested or would like to contact us for any reason at all.
You just open bid a job that was awarded a couple weeks ago. That is two strikes against you already and you just joined.
