Greg,
If you haven't chosen a vendor yet, you may want to consider "The Electrical Materials Company"
Electric Materials They've been around for a very long time, and have a lot of expertise in electrical copper work.
You can't put a design on a PM forum without having at least one self-declared expert give it a critique! :-) Here goes:
Copper is crazy expensive, over the last 5 years or so it has gotten insane. Being frugal with copper in your design has become pretty worthwhile financially. The long-axis cross section of the design is 8mm x 2mm = 16mm^2, which is slightly less than 5 AWG wire. When used in *chassis* wiring, 5 AWG is good for a little less than 120 amps. I don't know how big a battery you're connecting to, but I noticed that your terminal screw was 2-56, so I was guessing that the battery is pretty small. Having made a couple groundless assumptions already, I pressed on and thought that maybe the 8mm dimension was to contact the full width of the battery's wiper-style contact, and so you didn't really have much control over that, but the 2mm dimension might be driven by simply having a deep enough hole for the 2-56 thread to engage 4 or so threads in. If that's the case, then I'd like to suggest that you consider reducing the thickness from 2mm down to something smaller, everywhere except for an area around the hole - this could be kept at 2mm.
Let's say you left half the contact at 2mm thick, and reduced the other half to 1mm thick. You'll have saved 25% of the copper from your original design. To find out how much that is, and the cost savings, here's a rough calculation (the factor 0.00001975 lb/mm^3 is just the density of copper)
14.9mm x 8mm x 2mm x 20,000/year x 0.00001975 lb/mm^3 = 94.2 lb
So, 25% of that yearly total is about 23 pounds every year. I don't know prices on 360 copper, but 110 copper in this sort of quantity will set you back about $12/lb. That's a total savings of $276/year, or easily beer money for a couple months.
That's more than enough whining from me! Good luck with your product!
Dave
