RFQ - custom precision screw assembly
Results 1 to 17 of 17
    Jul 2018
    Maryland
    10
    Default RFQ - custom precision screw assembly
    Due to the upload size limit, I've done a screen capture of the pieces and attached them here. I'm not looking for the cheapest, my priority is in the quality and speed. Thanks for your consideration.
    I need 6 sets of this assembly. I need two quotes:
    1. made with #6-40 thread on the shaft and the nut
    2. thread pitch much greater than 40 and up to 220tpi.
    Attached Thumbnails Attached Thumbnails screw1.jpg   screw1a.jpg   screw1b.jpg   screw1c.jpg
    Jan 2007
    Flushing/Flint, Michigan
    6,464
    271
    5261
    So the "flexible" middle part has a .030 min wall but no max?
    So it could be solid?
    I will not touch the handful of other oops here.
    Jul 2006
    Hillsboro, New Hampshire
    4,963
    1164
    3471
    Yeah, that design is what I'd call a hot mess...
    Oct 2005
    10,636
    17668
    5600
    No matter...that idea of screen shots for posting worked out very well.
    No zipped files to deal with, no tiny prints we (the older members) can't read.
    very nice.
  5. Likes chris9911 liked this post
    Nov 2014
    Florida
    2,159
    1058
    1093
    Quote Originally Posted by chris9911 View Post
    The 6-40 thread is doable for sure, but 6-220?!?
    Sep 2002
    gloucester ma
    1,850
    70
    1336
    I 'think' the first image takes care of that, defining model as master, and .01 tolerance
    positive zero clearance fit?
    not something I have heard of and doesn't google
    220 tpi?
    purty teeny
  8. Likes chris9911 liked this post
  9. #7
    Jul 2018
    Maryland
    10
    no oops, the drawing is an inspection drawing for acceptance. CAD is the master for mfg. Iges or stp files will be provided.
  10. #8
    Jul 2018
    Maryland
    10
    I am still interested in 6-40. 6-100+ means you have the job with more orders to come.
  11. #9
    Jul 2018
    Maryland
    10
    220 tpi?
    purty teeny
    no doubt this is a tough job. I am still interested in 6-40. 6-100+ will mean you got the job.
  12. #10
    Jul 2018
    Maryland
    10
    very nice.
    Exactly, and no worrying over computer virus.
  13. #11
    Jul 2018
    Maryland
    10
    220 tpi?
    purty teeny
    Excellent question on the positive zero clearance. Rather than putting in 4decimal place inspection dimensions, I just care the titanium flex piece fits nice and tight with almost zero slack. Best way to describe it would be, press fit by hand while it can still rotate around the shaft. Does that answer your question? It's probably the most critical question asked so far. Thank you.
  14. #12
    Jul 2018
    Maryland
    10
    You haven't seen hot mess until you've seen the engineering/mfg drawing for this. 5place decimal dimensions everywhere with angular tolerance of +/-.008 deg.
  15. #13
    May 2005
    AZ
    2,200
    193
    733
    Having done a fair amount of prototyping and instrument development work, this is often an area of subjective judgment in defining "almost zero slack". Your literal description of the fit is something I would call a "close slip fit", as "press fit by hand" is something pf an oxymoron. Having some numbers is always helpful when committing to actual part production. In my estimation, you are looking at something like +.0001/.0002" over the mating part diameter
    Assuming that definition isn't a fatal obstacle, have you considered adapting off the shelf hardware for the application, such as the Thorlabs Extremely Fine Hex adjuster series of components? I think they offer 6-80, as well as M2.5 and M3 x 0.20 pitch, which would translate to about 127TPI. Could the shaft component be made from two pieces?
    Do you have expectations of small radii in the internal corners of the flexure, or sharp corners?
    Last, how close do the threads need to be to the shoulder, on the short end of the shaft part? This could relate to the above question about two-piece construction as well.
  16. #14
    Jul 2018
    Maryland
    10
    Quote Originally Posted by specfab View Post
    yes, thorlab and few other precision lab instrument companies do offer off the shelf adjuster sets with very high thread pitch, and I think its a fantastic idea for you to order the stock parts and turn those down as needed. .0001" clearance would be ideal, but I don't like dimensioning something that I cannot inspect. I would think the flexure piece has to be inserted into the shaft before cutting thread on the long side and certainly before pressing in the hex key. I want to receive a fully assembled assembly. My only verification on the clearance fit will be a 'slide and rotation' test to verify its near tight. A clearance gap at this joint will negate any type of precision I'm trying to achieve with the high thread pitch. What if you sent me two quotes. One with a standard 6-40 and 6-40+ using off the shelf items(something I might be able to provide). If you can make it with 6-40 with quick turnaround time, I would order 6 sets of that and another 6 to 12 sets of the 6-40+ version, since that might need some R&D time. To answer your other questions. The shaft can be broken in to two pieces if you want to use the off-the-shelf item. The nut shape can be anything as long as it has some kind of hex exterior shape. All entities not called out in the drawing is default profile and form tolerance of .01" which includes the radius. There is one critical inspection dimension that measures radius to radius on the flex part, you can machine it material safe and go slightly higher and start hand filing till you hit that dimension. I think you truly understand the design intent of this assembly, and would love to see your quote. Thanks.
  17. #15
    May 2005
    AZ
    2,200
    193
    733
    Thanks for the vote of confidence, but I wouldn't be able to quote this right now for any sort of quick delivery. I am in the middle of a complex instrument development project that will likely run an additional couple of months longer from today. Perhaps the info we have discussed will help someone else quote the work for you. Good luck --
  18. #16
    Jul 2018
    Maryland
    10
    Yes, thanks for chiming in, lots of useful information exchanged here.
  19. #17
    Jul 2018
    Maryland
    10
    ******RFQ closed****
