Joe Miranda
Titanium
- Oct 19, 2004
- Elyria Ohio
I am making "in between" sizes of motorcycle valve shims and need to permanently engrave the size on the valve shim. It would be best to put the size on the "edge" of the valve shim but if it can be engraved so as not to change the size or surface finish of the face then that would be tolerable.
These are going to be small batches - 10 of each size at a time with 5 different sizes - so 50 total at a time ('cause that's all I can stand making or my add kicks in).
Photos attached. The one in the photo I had done at a trophy shop and it is actually raised so that is no good because the cam lobe rides on one surface and the other rides against the valve bucket so the surfaces have to remain unaffected by the engraving.
