RFQ - Holes drilled in two large taps
Likes Likes:  0
Results 1 to 10 of 10
    Mar 2004
    Granada Hills, CA
    498
    Post
    Hey all,
    I need a through hole down the length of two taps. Taps are HSS 1.37"x24tpi.
    Required is a 0.375" (+0.005 -0.000; True Position 0.005") Hole down the length.
    Any takers?
    nK
    Jan 2005
    Iowa
    244
    Post
    I'm afraid I have nothing to offer except a question.
    Why would you want a hole in a tap?
    Oct 2006
    The Land Of Lincoln, where the air still smells fresh (SOME PLACES TOO FRESH)
    595
    6
    Post
    Being a large tap, to be used in a "THROUGH THE SPINDLE COOLANT MACHINE?"
    Thats my $0.02 worth!!!
    SteelCutter
    Jan 2003
    Canada
    11,129
    5158
    3242
    Post
    Or to hold another tool in it and run 2ops.
    There's gotta be someone here with an EDM, maybe you could post this on that part of the forum too?
    Mar 2004
    Granada Hills, CA
    498
    Post
    Bicycle bottom bracket threads. A rod is placed through them to assure concentricity.
    nK
    Jan 2005
    Iowa
    244
    Post
    Ahh, that makes sense.
    Cutter, coolant was my first thought too, but the tight tolerance didn't make sense for that.
    Sorry to invade on your thread Sloeit, just my curiosity got the better of me again.
    May 2002
    South Central PA
    13,390
    2143
    3327
    Post
    This doesn't answer your question, but if I may offer an alternative - Could you make a body to hold 24TPI chasers from a collapsible tapping head? You can build it with an alignment arbor built in, and might be cheaper than the spec. taps.
    Mar 2004
    Granada Hills, CA
    498
    Post
    Mudflap...not sure what your speaking of. However I already purchased the Taps from the UK. $40ea.
    Bought two extra's....Friends XMas present...
    nK
    May 2002
    South Central PA
    13,390
    2143
    3327
    Post
    OK, never mind then.
    Could you maybe carefully TIG weld a boss to the end of the tap, bore it,insert a rod and true up the rod? I'm thinking of a rig I made up to true MC steering necks after they were welded - cut one end while piloting off the other end.
    Aug 2007
    Provo Utah
    32
    Post
    Send them to me. I can pop a start hole, then WEDM to size. The taps should have centers which are the datums for the ground thread. We may need to grind the shank between the centers so we have a good datum to locate from. [email protected] . Chris
