RFQ - Large CNC Router Base Machining - Detroit Michigan Area
Scott.Damman
Jan 10, 2016
Looking for a quote to have a CNC router base and gantry machined. Can give all details to whoever has machining capability large enough, below are the rough outside dimensions. Sorry for the rough drawings have full 3d model of the machine that can be shared in whatever format required.
Main Frame 154in x 84in ~30in Tall
Main Frame Machining Operations (Detailed drawings attached)
X Axis Rail
- 49 Holes Drilled and tapped for M8 bolts (per side 2 sides)
- Machine Mount and Rail Side Reference (2 sides)
- 10 holes for rail lock (see drawing) Per side.
With M3 tapped hole in bottom (per side 2 sides)
Other
- Machine 4 bearing block mount locations (2 per side)
- Surface main bed. Flat minimal material removal.
No thickness specified
Gantry 92in x 36in x20in (foot width)
Gantry Machining Operations (Detailed drawings attached)
Y Axis Rail
- 39 Holes Drilled for M6 bolt clearance (Top and Bottom)
- Machine Mount and Rail Side Reference (Top and Bottom)
Other
- Machine 2 bearing block mount locations
- Machine X Axis bearing block mount and reference
(Left and Right)
- Drill X Axis bearing block mount holes for M10 clearance
(4 per block, 2 blocks per side, 2 sides)
