Magnasanti
- Oct 12, 2012
- Ga,USA
Hello,
I'd like 1 or 2 depending on the quote of the attached drawings in 6061-T6 aluminum. Tolerance of +/-.01mm is fine. There are 2 threaded holes the first is the 4mm holes which is a m4.7x. The second is the blue hidden line which is a 8/32". Then there is a counter bore of 4mm at the 8.5mm/6mm bore. The angles for the holes are 90, 23, and 45
EDIT.. Noticed you cant see anything in the attachment here is a link to a full size image. I also have the 3d inventor file if needed.
Imgur: The most awesome images on the Internet
Please contact me via PM.Or post here
